[mapserver-users] PHP $imgObj->saveImage(null) sends headers
Miloslav Kmeť
miloslav.kmet at gmail.com
Mon Apr 5 13:21:49 EDT 2010
Hi. I am trying to use php_mapscript in MVC framework (symfony) and I want to
catch the output of $imgObje->saveImage(null); for the later processing, eg:
using the builtin cache mechanism instead of directly writing the file to the
cache.
My code very simplified looks like:
ob_start(); // start output buffering
$imgObj->saveImage(null); // print output to std
$image = ob_get_clean(); // get the buffer and clen it
header('Content-type: image/jpeg'); // setting the header
echo $image; // printing the image
At the header line I got an header already sended error, even no output will
be brinted before.
I looked into php_mapscript.c and I found that in the saveImage function there
is php_header(TSRMLS_C); As I do not know the PHP internals, i do not know
what that call is doing, but when I removed it out, and recompiled the
extension,
Now output buffering is working correctly.
What is the function doing? Should it be replaced in the main development?
Thanks
Miloslav Kmeť
Type: text/x-patch
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100405/2330f9e6/php_mapscript.bin
