[mapserver-users] PHP $imgObj->saveImage(null) sends headers
Pavel Iacovlev iacovlev.pavel at gmail.com
Mon Apr 5 13:37:02 EDT 2010
Oh sorry, your code is correct thought you used ob_end_clean and you
are using ob_get_clean. But the snippet works for me with out any
phpmapscript modification.
2010/4/5 Pavel Iacovlev <iacovlev.pavel at gmail.com>:
> 1) Your php code is not correct I think, ob_get_clean  just cleans the
> output and does not return the captured content.
> 2) Try with no framework, maybe it sends some headers before you run your code.
> This works for me in Zend Framework in MVC mode, should work for symfony too.
> ob_start();
> $image->saveimage('');
> $image = imagecreatefromstring(ob_get_contents());
> ob_end_clean();
> imagepng($image);
> 2010/4/5 Miloslav Kmeť <miloslav.kmet at gmail.com>:
>> Hi. I am trying to use php_mapscript in MVC framework (symfony) and I want to
>> catch the output of $imgObje->saveImage(null); for the later processing, eg:
>> using the builtin cache mechanism instead of directly writing the file to the
>> cache.
>> My code very simplified looks like:
>> ob_start();                            // start output buffering
>> $imgObj->saveImage(null);  // print output to std
>> $image = ob_get_clean();   // get the buffer and clen it
>> header('Content-type: image/jpeg'); // setting the header
>> echo $image; // printing the image
>> At the header line I got an header already sended error, even no output will
>> be brinted before.
>> I looked into php_mapscript.c and I found that in the saveImage function there
>> is php_header(TSRMLS_C); As I do not know the PHP internals, i do not know
>> what that call is doing, but when I removed it out, and recompiled the
>> extension,
>> Now output buffering is working correctly.
>> What is the function doing? Should it be replaced in the main development?
>> Thanks
>> Miloslav Kmeť
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> http://iap.md, The future is open
