[mapserver-users] record element in query header
Steve.Toutant at inspq.qc.ca
Wed Apr 7 14:07:24 EDT 2010
Jeff, the DATA of this layer is a postgis view and the field is really
[provincename].
If I put [provincename] in the template I got the value, per example
In the Template
[lrn]: [provincename] - [elementname]<br>
The result is:
1: Québec - blabla 1
2: Québec - blabla 2
3: Québec - blabla 3
But I don't want to put it in the template since the same information will
be repeated.
thanks for your help!
Steve
Jeff McKenna <jmckenna at gatewaygeomatics.com>@lists.osgeo.org
Envoyé par : mapserver-users-bounces at lists.osgeo.org
07/04/2010 01:58 PM
A
mapserver-users at lists.osgeo.org
cc
Objet
Re: [mapserver-users] record element in query header
Steve.Toutant at inspq.qc.ca wrote:
> Hi,
> Is it possible to get the value of a record and put it in the header?
> Here is an example of what I need to do
> There are 3 elements in Quebec
> 1: blabla 1
> 2: blabla 2
> 3: blabla 3
> Here is my template definition
> Header
> There are [nlr] elements in [provincename]
> Template
> [lrn]: [elementname]<br>
> What I get is:
> There are 3 elements in [provincename]
> 1: blabla 1
> 2: blabla 2
> 3: blabla 3
> How can I get the [provincename] value in the header?
Steve,
You should be careful of string case. You should verify the case by
using ogrinfo with the -summary switch to see what the correct name is:
ogrinfo quebec.shp quebec -summary
The result may be [PROVINCENAME].
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100407/4b6cf5e4/attachment.html
