[mapserver-users] can not compile arcsde 9.3 with mapserver 5.4
Lime, Steve D (DNR)
Steve.Lime at state.mn.us
Wed Apr 7 17:40:04 EDT 2010
Don't know if success was had or not. The standard 9.3 disks I had access to did not have the headers available. Must need some super secret handshake to get them. Anyway, I just copied the 9.2 headers into the same spot in the 9.3 directories and it works just fine. Don't know that I'd recommend that approach in lieu of learning the super secret handshake but it worked here in a pinch...
Steve
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Huey Brantley
Sent: Thursday, March 18, 2010 10:44 PM
To: Jachym Cepicky
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] can not compile arcsde 9.3 with mapserver 5.4
Compile it against the SDE SDK, not where you have SDE installed.
My configure:
./configure \
--with-php=/usr/local \
--with-proj=/usr/local \
--with-gd=/usr/local \
--with-jpeg=/usr/local \
--with-png=/usr/local \
--with-sde=/u01/arcgis93sdk/sdeexe93/ \
--with-sde-version=93 \
--with-wfs \
--with-ogr=/usr/local/bin/gdal-config \
--with-gdal=/usr/local/bin/gdal-config \
--with-freetype \
--with-tiff \
--with-agg \
--with-curl \
--enable-debug
Jachym Cepicky wrote:
> Hi,
> I'm not able to get arcsde 9.3.0 compiled with mapserver (5.4), on Linux
> I use
> ./configure --with-sde=/opt/arcsde/9.3.0/sdeexe93/ --with-sde-version=''
> the arcsde installation directory containes (among others) file
> libsde.so
> nut not "*.a" file or "*.h" files
> however, I get
> configure: error: "Could not find sdetype.h or libsde.a/libsde.so in
> /opt/arcsde/9.3.0/sdeexe93/."
> Any hint?
> Thanks
> Jachym
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
