[mapserver-users] Dynamically generated Raster images in mapfile
adams
adams at terrestris.de
Thu Apr 8 09:12:05 EDT 2010
Heiko,
If you know your generated filename you also could add it as
Vendorspecific parameter to the map-request:
Request http://.... map=/path/to/mapfile.map¶ms....
&filename=yourfile.tif
In the mapfile you need sth. like that:
LAYER
TYPE RASTER
DATA /path/to/%filename%
I'm not quite sure, if I hit the correct syntax just from mind. See here:
http://mapserver.org/mapfile/variable_sub.html
Till
Jörg Thomsen wrote:
> Hello Heiko,
> Heiko Schröter wrote:
>> i need to create Raster images on the fly and place them on a map
>> generated with Mapserver.
>> The time needed for generating these images is not crucial.
>> An external script is triggered to generate these images.
>> 1) Is it possible to define in a mapfile a "data/image source" coming
>> from a script ?
> I don't think, that it would work with
> DATA 'anyscript'
> because this is reading the source, not executing it.
> But a WMS is doing what you are asking for:
> so perhaps you could use your script as WMS and call it with
> CONNECTIONTYPE WMS
> CONNECTION "http://.../yourscript"
> you could add the parameters your script needs directly to the
> connection-string.
> CONNECTION "http://.../yourscript?param1=gtf>2=..."
> Regards, Jörg
>> or
>> 2) Is it possible to rediret the output of the script as input to
>> mapserver ?
>> Stepping through the docs the only solution i can think of in the
>> moment is to generate a temp.img (and temp.tlw)and pass that filename
>> as variable to the DATA tag inside the mapfile.
>> Any pointer to some more infos is highly appreciated.
>> Preprocessing is not a solution since we have dozends of options for
>> generating the images.
>> Thanks and Regards
>> Heiko
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
terrestris GmbH & Co. KG
Irmintrudisstrasse 17
53111 Bonn
Germany
Till Adams
Geschäftsführung
Tel: +49 (0)228 / 962 899-52
Fax: +49 (0)228 / 962 899-57
adams at terrestris.de http://www.terrestris.de
Amtsgericht Bonn, HRA 6835
Komplementärin:
terrestris Verwaltungs GmbH
vertreten durch:
Hinrich Paulsen, Till Adams
