[mapserver-users] contours in mapfile
Fawcett, David (MPCA)
David.Fawcett at state.mn.us
Thu Apr 8 11:27:00 EDT 2010
Oz,
In looking at your layer definition, you have defined a layer extent in coordinates that don't appear to match the spatial reference system you have defined for that layer in the projection block.
It looks like you have meters or feet in your extent and the units for the projection that you have defined are decimal degrees.
I would suggest getting rid of your layer extent unless you really need it. Make sure that the projection that you have defined in your layer matches the projection of your data.
At the map level (you didn't include this part of the map file), make sure that the units of your map extent match the projection of your map.
The best approach is to simplify your map file as much as possible to get it working.
David.
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Oz Nahum
Sent: Thursday, April 08, 2010 9:49 AM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] contours in mapfile
Hi Everyone,
I am trying to display an ESRI ASCII Raster with map file in a contoured form.
Despite following the documentation here:
http://mapserver.org/input/raster.html#how-are-rasters-added-to-a-map-file
I fail, and get an empty map...
Here's is what I try in the mapfile:
MAP
#IMAGETYPE JPEG
# "minx miny maxx
maxy"
EXTENT 3366307.654280 5813354.151378 3367797.654280 5814955.151378
SIZE 640 480
IMAGECOLOR 255 255 255
FONTSET "/home/oz/safira/Safira2/trunk/Safira2/DATA/fonts/fonts.list"
# Background color for the map canvas -- change as desired #if another color uncomment #IMAGECOLOR 192 192 192 IMAGEQUALITY 100 IMAGETYPE jpeg OUTPUTFORMAT
NAME jpeg
DRIVER 'GD/JPEG'
MIMETYPE 'image/jpeg'
IMAGEMODE PC256
EXTENSION 'jpeg'
END
# Legend
LEGEND
STATUS embed
#IMAGECOLOR 255 255 255
POSITION ll
#STATUS ON
KEYSIZE 10 10
LABEL
TYPE truetype
FONT "arial"
COLOR 0 0 0
SIZE 8
ANTIALIAS true
END
END
### SCALEBAR
SCALEBAR
#ALIGN center
INTERVALS 4
POSITION ul #ur
SIZE 200 10
#Black bounding box
OUTLINECOLOR 0 0 0
STATUS embed
UNITS kilometers
LABEL
TYPE truetype
FONT "arial"
COLOR 0 0 0
SIZE 8
ANTIALIAS true
END
END
LAYER
NAME 'W_PCE_in_GW'
TYPE RASTER
DUMP true
TEMPLATE fooOnlyForWMSGetFeatureInfo
EXTENT 3365691.535626 5813306.316297 3368142.408444 5815201.783992
DATA '/home/oz/safira/Safira2/trunk/Safira2/SzenarioA/ScALayout1/W_PCE_in_GW.asc'
METADATA
'ows_title' 'W_PCE_in_GW'
END
STATUS ON
CLASSITEM "[pixel]"
#MAXSCALE 500000
CLASS
NAME "NO DATA"
EXPRESSION (([pixel] == -9999))
COLOR 0 0 255
STYLE
#SYMBOL 0
#SIZE 4
#OUTLINECOLOR 0 0 255
#COLOR 243 162 0
END
END
CLASS
NAME "0 - 5"
EXPRESSION (([pixel] >= 0 AND ([pixel] <=5))
COLOR 200 0 0
STYLE
SYMBOL 0
SIZE 2
OUTLINECOLOR 0 0 0
#COLOR 243 162 0
END
END
CLASS
NAME "5 - 10"
EXPRESSION (([pixel] > 10 AND [pixel] <=20))
COLOR 243 162 0
END
CLASS
NAME "2 - 50"
EXPRESSION (([pixel] > 20 AND [pixel] <=50))
COLOR 0 200 0
END
TRANSPARENCY 100
PROJECTION
'proj=longlat'
'ellps=WGS84'
'datum=WGS84'
'no_defs'
END
END
END
I also attach the raster file as zip.
Can someone tell me what am I doing wrong ?
Thanks in advance !
Oz Nahum
Graduate Student
Zentrum für Angewandte Geologie
Universität Tübingen
