[mapserver-users] RE: What is valid format for attribute color
in PostGIS ?
Rafal Magda
crus1 at o2.pl
Sun Apr 11 17:19:41 EDT 2010
On 11 April 2010 21:36, Pano Voudouris <pvoudouris at gaiocorp.com> wrote:
> What is the actual value in the field? TEXT "255 0 0" or just "255 0 0". I
> think only the second will work.
> Pano
It was "255 0 0" only, and column type was TEXT.
I solved this problem by simply removing the first STYLE. I found that when
using COLOR attribute there can be only one STYLE... But it is nowhere
documented, so I consider it as a bug.
BTW: Empirically I also found another valid format: "#ff0000".
PS: Sorry for starting 2 duplicated threads.
Rafał Magda
View this message in context: http://n2.nabble.com/What-is-valid-format-for-attribute-color-in-PostGIS-tp4885606p4887119.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
