[mapserver-users] OGR tileindex creates unnecessary lines into error log
Mon Apr 12 23:00:56 EDT 2010
Rahkonen Jukka wrote:
> Hi,
> I created an OGR tileindex layer as described in document
> http://mapserver.org/input/vector/ogr.html
> The document tells " The CONNECTION keyword is not needed (and will be
> ignored) for layers using the OGR connection type and having the
> TILEINDEX keyword."  This seems to be true and my layer works fine.
> However, the MS_ERROR file collects these error messages:
> msConnPoolRegister(): Missing CONNECTION on layer ....
> msConnPoolRegister(): General error message. Missing CONNECTION
> This Mapserver seems to be a bit old, it is of version 5.2.1.  I did not
> find a ticket about this from trac. Has anybody else noticed those
> unnecessary error messages?
I agree this output is not appropriate in this situation. I have applied
a fix in trunk to avoid this:
If you are able to test this, I would be willing to migrate it back to 5.6
stable (after testing).
Best regards,
