[mapserver-users] Strange Behaviour with getFeature using
POSTmethod and more than one typename
David Alda Fernandez de Lezea
dalda at ikt.es
Tue Apr 13 08:28:42 EDT 2010
Assefa,
I'm using version 5.2.1, but we are not sure if we are going to migrate
or not.
This is what I get:
Request:
<?xml version="1.0" ?><wfs:GetFeature service="WFS" version="1.1.0"
outputFormat="text/xml;
subtype=gml/3.1.1"xmlns:wfs="http://www.opengis.net/wfs"
xmlns:ogc="http://www.opengis.net/ogc"xmlns:xsi="http://www.w3.org/2001/
XMLSchema-instance" xsi:schemaLocation="http://www.opengis.net/wfs
../wfs/1.1.0/WFS.xsd">
<wfs:Query typeName="PoligonosSigpac">
<ogc:Filter>
<ogc:Or>
<PropertyIsEqualTo><ogc:PropertyName>GID</ogc:PropertyName><Literal>1</L
iteral></PropertyIsEqualTo>
<PropertyIsEqualTo><ogc:PropertyName>GID</ogc:PropertyName><Literal>65</
Literal></PropertyIsEqualTo>
<PropertyIsEqualTo><ogc:PropertyName>GID</ogc:PropertyName><Literal>197<
/Literal></PropertyIsEqualTo>
<PropertyIsEqualTo><ogc:PropertyName>GID</ogc:PropertyName><Literal>245<
</ogc:Or>
</ogc:Filter>
</wfs:Query>
</wfs:GetFeature>
Debug info of the request:
[Tue Apr 13 14:05:51 2010].39000 CGI Request 1 on process 3408
[Tue Apr 13 14:05:51 2010].54000 msOracleSpatialLayerOpen called with:
GEOMETRY FROM (SELECT * FROM GX_SIGPAC_POLIGONOS) USING UNIQUE gid SRID
82337
[Tue Apr 13 14:05:51 2010].164000 msOracleSpatialLayerOpen. Shared
connection not available. Creating one.
msConnPoolRegister(PoligonosSigpac,admcarto/admcarto at ORA10GEX,01C6FA48)
[Tue Apr 13 14:05:51 2010].164000 msOracleSpatialLayerFreeItemInfo was
called.
[Tue Apr 13 14:05:51 2010].164000 msOracleSpatialLayerGetItems was
called.
[Tue Apr 13 14:05:51 2010].164000 msOracleSpatialLayerInitItemInfo was
called.
called.
[Tue Apr 13 14:05:51 2010].164000 msOracleSpatialLayerClose was called.
Layer name: PoligonosSigpac. Layer connection:
[Tue Apr 13 14:05:51 2010].164000 msOracleSpatialLayerClose. Cleaning
layerinfo handlers.
Oracle Cache.
[Tue Apr 13 14:05:51 2010].164000 msOracleSpatialLayerClose. Release the
Oracle Pool.
msConnPoolRelease(PoligonosSigpac,admcarto/admcarto at ORA10GEX,01C6FA48)
msConnPoolClose(admcarto/admcarto at ORA10GEX,01C6FA48)
[Tue Apr 13 14:05:51 2010].164000 msOracleSpatialLayerOpen called with:
82337
[Tue Apr 13 14:05:51 2010].210000 msOracleSpatialLayerOpen. Shared
[Tue Apr 13 14:05:51 2010].226000 msOracleSpatialLayerFreeItemInfo was
called.
[Tue Apr 13 14:05:51 2010].226000 msOracleSpatialLayerWhichShapes was
called.
[Tue Apr 13 14:05:51 2010].226000 msOracleSpatialLayerWhichShapes. Using
this Sql to retrieve the data: SELECT gid, GEOMETRY FROM (SELECT * FROM
GX_SIGPAC_POLIGONOS) WHERE (GID= 1) Or ( (GID= 65) Or ( (GID= 197)
Or (GID= 245) ) ) AND SDO_FILTER( GEOMETRY, MDSYS.SDO_GEOMETRY(2003,
82337,
NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,3),MDSYS.SDO_ORDINATE_ARRAY(463498
.785,4702415.35,603167.124,4811812.82) ),'querytype=window') = 'TRUE'
[Tue Apr 13 14:05:51 2010].257000 msOracleSpatialLayerFreeItemInfo was
called.
[Tue Apr 13 14:05:51 2010].257000 msOracleSpatialLayerClose was called.
[Tue Apr 13 14:05:51 2010].257000 msOracleSpatialLayerClose. Cleaning
layerinfo handlers.
Oracle Cache.
[Tue Apr 13 14:05:51 2010].257000 msOracleSpatialLayerClose. Release the
Oracle Pool.
[Tue Apr 13 14:05:51 2010].288000 msOracleSpatialLayerOpen called with:
82337
[Tue Apr 13 14:05:51 2010].335000 msOracleSpatialLayerOpen. Shared
[Tue Apr 13 14:05:51 2010].335000 msOracleSpatialLayerFreeItemInfo was
called.
[Tue Apr 13 14:05:51 2010].335000 msOracleSpatialLayerGetItems was
called.
[Tue Apr 13 14:05:51 2010].335000 msOracleSpatialLayerInitItemInfo was
called.
[Tue Apr 13 14:05:51 2010].335000 msOracleSpatialLayerGetShape was
called. Using the record = 65.
[Tue Apr 13 14:05:51 2010].335000 msOracleSpatialLayerGetShape. Sql:
SELECT GID, PROVINCIA, MUNICIPIO, POLIGONO, DN_SURFACE, DN_PERIMET,
FECHA_INI, FECHA_FIN, GEOMETRY FROM (SELECT * FROM GX_SIGPAC_POLIGONOS)
WHERE gid = 65 AND (GID= 1) Or ( (GID= 65) Or ( (GID= 197) Or
(GID= 245) ) )
called. Using the record = 1.
WHERE gid = 1 AND (GID= 1) Or ( (GID= 65) Or ( (GID= 197) Or
(GID= 245) ) )
[Tue Apr 13 14:05:51 2010].351000 msOracleSpatialLayerGetShape was
called. Using the record = 197.
[Tue Apr 13 14:05:51 2010].351000 msOracleSpatialLayerGetShape. Sql:
WHERE gid = 197 AND (GID= 1) Or ( (GID= 65) Or ( (GID= 197) Or
(GID= 245) ) )
called. Using the record = 245.
WHERE gid = 245 AND (GID= 1) Or ( (GID= 65) Or ( (GID= 197) Or
(GID= 245) ) )
[Tue Apr 13 14:05:51 2010].351000 msOracleSpatialLayerFreeItemInfo was
called.
[Tue Apr 13 14:05:51 2010].351000 msOracleSpatialLayerClose was called.
[Tue Apr 13 14:05:51 2010].351000 msOracleSpatialLayerClose. Cleaning
layerinfo handlers.
Oracle Cache.
[Tue Apr 13 14:05:51 2010].351000 msOracleSpatialLayerClose. Release the
Oracle Pool.
[Tue Apr 13 14:05:51 2010].367000 mapserv request processing time
(msLoadMap not incl.): 0.328s
[Tue Apr 13 14:05:51 2010].367000 msFreeMap(): freeing map at 015D5F68.
[Tue Apr 13 14:05:51 2010].367000 msOracleSpatialLayerClose was called.
And the WFS response is
<?xml version='1.0' encoding="ISO-8859-1" ?>
<wfs:FeatureCollection
xmlns:ms="http://mapserver.gis.umn.edu/mapserver"
xmlns:gml="http://www.opengis.net/gml"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://mapserver.gis.umn.edu/mapserver
http://192.168.1.65/cgi-bin/mapserv.exe?map=../htdocs/MFD/ejemplo_wfs.ma
p&SERVICE=WFS&VERSION=1.1.0&REQUEST=DescribeFeatureType&
TYPENAME=PoligonosSigpac&OUTPUTFORMAT=text/xml; subtype=gml/3.1.1
http://schemas.opengis.net/wfs/1.1.0/wfs.xsd">
<gml:boundedBy>
<gml:Envelope srsName="EPSG:23030">
<gml:lowerCorner>507876.512623
4725415.908118</gml:lowerCorner>
<gml:upperCorner>559140.632916
4754027.254311</gml:upperCorner>
</gml:Envelope>
</gml:boundedBy>
<gml:featureMember>
<ms:PoligonosSigpac gml:id="PoligonosSigpac.65">
<gml:boundedBy>
<gml:upperCorner>509654.924986
4727430.060275</gml:upperCorner>
</gml:Envelope>
</gml:boundedBy>
<ms:msGeometry>
<gml:Polygon srsName="EPSG:23030">
<gml:exterior>
<gml:LinearRing>
<gml:posList srsDimension="2">508370.140478
4727315.545819 508335.867232 4727320.996035 508290.659396 4727330.184342
508247.515061 4727336.285225 508213.831723 4727342.360368 508177.893761
4727350.759952 508139.217777 4727358.067493 508106.542691 4727365.168198
508073.350896 4727379.742591 508042.031529 4727396.059870 508021.380782
4727407.028376 508000.141383 4727416.507020 507972.680877 4727426.806950
507960.779080 4727430.060275 507959.520472 4727426.009949 507955.353514
4727413.672367 507951.761294 4727403.038770 507940.152078 4727366.678616
507937.929127 4727359.369470 507935.747217 4727352.190681 507931.581751
4727338.475568 507925.955179 4727317.629036 507923.366757 4727305.684210
507921.980341 4727299.288189 507919.924662 4727289.763994 507919.501512
4727287.557569 507918.853104 4727284.206032 507917.556317 4727277.475035
507915.993360 4727269.347569 507915.966036 4727269.226537 507909.529718
4727241.919508 507903.103010 4727212.164555 507898.301770 4727189.894905
507893.683300 4727163.865132 507889.994402 4727135.453636 507884.446852
4727105.252936 507880.796683 4727084.976475 507879.258052 4727067.466825
507878.242666 4727054.723344 507877.734988 4727048.337643 507876.512623
4727036.468857 507901.689121 4727031.341055 507926.183367 4727028.446425
507950.525888 4727026.156712 507985.608118 4727022.743920 508015.284939
4727015.052783 508037.247246 4727010.861835 508069.146425 4727005.174678
508092.282870 4727000.994582 508089.277872 4726969.642533 508087.296632
4726943.531951 508091.298917 4726897.081602 508091.919707 4726888.779807
508095.065469 4726846.758955 508095.191947 4726838.419352 508095.297109
4726830.694036 508092.830917 4726814.132651 508089.703848 4726793.158617
508085.562445 4726764.690657 508079.301398 4726740.334254 508071.215454
4726708.734296 508069.656907 4726702.756900 508063.176492 4726678.000025
508053.145208 4726642.227951 508051.852827 4726637.619109 508046.386304
4726597.040250 508038.952405 4726541.743555 508037.000605 4726531.400374
508031.302195 4726501.152871 508023.621785 4726462.842562 508019.804997
4726432.336636 508016.059925 4726405.097817 508015.962530 4726400.257673
508015.308803 4726365.883391 508015.405821 4726335.465775 508014.912053
4726323.057972 508013.470935 4726286.700232 508011.971896 4726229.176607
508026.512006 4726179.071223 508028.904353 4726170.827332 508029.393851
4726169.143198 508052.468188 4726108.567252 508076.090025 4726049.928038
508080.642042 4726038.819900 508081.337592 4726037.117395 508096.646573
4725999.727449 508110.989526 4725966.441124 508111.375126 4725965.548032
508135.743929 4725914.905260 508171.199684 4725844.226772 508189.399434
4725807.873613 508196.585760 4725793.529576 508215.254371 4725790.535992
508231.024486 4725788.004400 508266.390519 4725782.331577 508365.455593
4725766.413314 508384.879769 4725763.402485 508410.519989 4725759.421944
508415.527148 4725758.646178 508455.969121 4725752.366183 508482.986724
4725717.215961 508500.347456 4725694.638053 508549.570764 4725629.125610
508597.013173 4725566.161632 508639.042793 4725510.358187 508661.455261
4725479.819566 508685.813878 4725447.338141 508698.078900 4725431.269762
508709.807420 4725415.908118 508711.487492 4725417.883472 508733.088271
4725443.330116 508756.273369 4725470.295994 508777.245610 4725492.903124
508802.260121 4725517.507312 508825.441333 4725541.727637 508843.070387
4725557.629135 508859.256350 4725568.828423 508874.812880 4725578.137470
508892.829081 4725586.528245 508911.747862 4725592.593292 508928.211276
4725596.179365 508947.038186 4725598.893604 508971.631261 4725603.486218
508999.339589 4725610.009670 509019.870954 4725616.914807 509041.116605
4725623.727859 509053.963702 4725625.075653 509067.102026 4725624.283070
509089.336347 4725620.756662 509113.982155 4725616.460957 509140.307380
4725614.531722 509153.526752 4725614.791186 509157.138904 4725614.861116
509167.618268 4725615.061137 509168.462930 4725615.080871 509169.966848
4725615.110786 509172.109418 4725615.150854 509180.137179 4725615.310417
509186.276462 4725615.430251 509205.415827 4725615.455669 509214.659310
4725615.467964 509228.463752 4725619.870295 509245.908707 4725628.801078
509266.850646 4725641.710991 509286.002956 4725657.634278 509307.178433
4725680.606300 509330.024251 4725712.488152 509356.982911 4725744.692101
509386.382826 4725774.209528 509409.755112 4725802.238955 509426.577993
4725823.706889 509447.670860 4725851.146957 509460.888344 4725872.554211
509474.960082 4725896.922525 509489.527443 4725925.359035 509501.304870
4725950.096571 509516.172709 4725984.583590 509526.792406 4726012.139830
509540.353888 4726042.641390 509551.154943 4726068.019906 509557.839801
4726090.479430 509561.384907 4726109.081215 509564.069424 4726124.312406
509564.459679 4726140.061664 509563.434889 4726161.123694 509563.562161
4726183.322863 509562.440193 4726210.118337 509562.503494 4726238.860770
509562.431992 4726260.799050 509564.975677 4726278.515222 509568.175738
4726293.300360 509574.010192 4726314.790726 509582.411063 4726337.494658
509588.746614 4726354.089853 509590.306503 4726373.079837 509588.785093
4726395.714195 509589.159036 4726428.142939 509586.513898 4726468.897948
509580.573918 4726498.972400 509573.997242 4726532.685311 509573.068354
4726558.894677 509575.920317 4726586.952209 509572.188843 4726628.850585
509577.842121 4726666.927146 509582.722965 4726692.539553 509584.190067
4726728.907009 509594.120718 4726772.043630 509603.691208 4726797.541556
509614.372955 4726828.700161 509624.999798 4726854.832516 509636.123603
4726879.038872 509645.984773 4726902.666407 509654.924986 4726936.735984
509633.800419 4726939.982883 509615.464111 4726942.786946 509610.608762
4726943.534132 509591.104806 4726946.653103 509545.242065 4726954.743305
509500.390426 4726961.606574 509497.354986 4726962.077105 509435.379554
4726973.962128 509417.054136 4726978.981980 509410.081899 4726981.345977
509377.700548 4726992.331730 509329.754895 4727007.792288 509320.449810
4727009.017684 509313.575740 4727009.911284 509290.453359 4727023.534700
509246.101320 4727047.554498 509207.617401 4727068.343281 509164.381481
4727089.898530 509126.277006 4727109.673721 509090.098268 4727132.337059
509067.768835 4727149.275826 509058.801415 4727160.228632 509043.970678
4727181.626407 509041.508058 4727185.188064 509023.025734 4727211.151228
509012.704374 4727218.006912 508979.662832 4727236.458496 508957.605756
4727250.317101 508956.849909 4727250.790819 508945.237337 4727258.091705
508943.616432 4727258.545691 508937.242692 4727260.343164 508930.999465
4727262.094273 508920.106433 4727265.161095 508877.586291 4727276.312974
508840.171674 4727284.213916 508836.024080 4727284.757777 508803.990153
4727288.933371 508767.495442 4727291.614218 508746.759555 4727292.732835
508712.381656 4727293.722635 508668.513405 4727296.264416 508636.606992
4727297.415920 508604.852191 4727298.120986 508564.557869 4727297.680078
508531.128179 4727298.113485 508492.603378 4727299.164420 508458.641561
4727302.445701 508425.942066 4727306.547768 508385.948362 4727313.023936
508370.140478 4727315.545819 </gml:posList>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</ms:msGeometry>
</ms:PoligonosSigpac>
</gml:featureMember>
<gml:featureMember>
<ms:PoligonosSigpac gml:id="PoligonosSigpac.1">
<gml:boundedBy>
<gml:lowerCorner>529575.602797
4753999.660256</gml:lowerCorner>
<gml:upperCorner>529612.280989
</gml:Envelope>
</gml:boundedBy>
<ms:msGeometry>
<gml:exterior>
<gml:LinearRing>
<gml:posList srsDimension="2">529580.641695
4754027.254311 529578.565694 4754018.588615 529575.602797 4754006.232999
529577.786673 4754005.739761 529605.580625 4753999.660256 529607.454087
4754004.536595 529608.306230 4754006.764963 529609.983399 4754011.165731
529610.151849 4754011.752883 529611.822510 4754017.661573 529612.280989
4754019.190118 529580.641695 4754027.254311 </gml:posList>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</ms:msGeometry>
<gml:featureMember>
<gml:boundedBy>
</gml:Envelope>
</gml:boundedBy>
<ms:msGeometry>
<gml:exterior>
<gml:LinearRing>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</ms:msGeometry>
<gml:featureMember>
<gml:boundedBy>
</gml:Envelope>
</gml:boundedBy>
<ms:msGeometry>
<gml:exterior>
<gml:LinearRing>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</ms:msGeometry>
</wfs:FeatureCollection>
-----Mensaje original-----
De: Yewondwossen Assefa [mailto:yassefa at dmsolutions.ca]
Enviado el: martes, 13 de abril de 2010 13:09
Para: David Alda Fernandez de Lezea
CC: mapserver-users at lists.osgeo.org
Asunto: Re: [mapserver-users] Strange Behaviour with getFeature using
David,
> Assefa,
> Thanks for your response. I had that configured in the waye you told
me this is what I get:
> [Fri Apr 09 11:24:45 2010].725000 CGI Request 1 on process 1948 [Fri
Apr 09 11:24:46 2010].37000 mapserv request processing time (msLoadMap
not incl.): 0.312s [Fri Apr 09 11:24:46 2010].37000 msFreeMap(): freeing
map at 015D60B8.
>> You should be able to check then the query sent to the oracle db and
that might give your more hints.
> Where I can view the query sent to Oracle??
> Thanks.
I forgot to mention that you also need to have the debug statement in
your layer for layer specific debug output in oracle.
Layer
DEBUG 5
END
I am not sure what version of MapServer your are using, but you should
if not already (and possiible) upgrade to 5.6.3 or the trunk version
from svn. Both have a lot more debugging information for the oracle
spatial.
