[mapserver-users] Strange Behaviour with getFeature using POST
method and more than one typename
David Alda Fernandez de Lezea
dalda at ikt.es
Wed Apr 14 02:39:43 EDT 2010
Assefa,
> From the url you sent, you seem to be on a windows machine, is that
correct?
Yes, I'm currently on a windows machine. I've got ms4w package (MS4W
Base Installer v2.3.1 (Dec 2, 2008) to be precise)
> I am trying to see if it is possible to provide you binaries
with the patch. I can provide this service for a fee myself or though an
associate.
Does this mean that I have to pay to get the binaries with the patch?
We are planning to to get this working in production level, so it would
be desirable to have a stable version of MapServer. What would you
recommend as best (not to much complicated and short in time) solution?
Thanks.
-----Mensaje original-----
De: Yewondwossen Assefa [mailto:yassefa at dmsolutions.ca]
Enviado el: martes, 13 de abril de 2010 18:42
Para: David Alda Fernandez de Lezea
Asunto: Re: [mapserver-users] Strange Behaviour with getFeature using
POSTmethod and more than one typename
David Alda Fernandez de Lezea wrote:
> Assefa,
> Thanks one more time. I hope this will be a strong reason to migrate
> to the latest version. Until that happens, I don't know really how I
> have to proceed to update my mapserver version with this patch. Should
> I re-compile the application?? How should I proceed??
Yes you need to recompile or get binaries that has the patch. From the
url you sent, you seem to be on a windows machine, is that correct? If
that is the case, where did you get your binaries (ms4w, other
sources)? I am trying to see if it is possible to provide you binaries
associate.
Let me know.
best regards,
> Thanks.
> De: Yewondwossen Assefa [mailto:yassefa at dmsolutions.ca] Enviado el:
> martes, 13 de abril de 2010 16:22
> CC: mapserver-users at lists.osgeo.org
>> Assefa,
>> I'm using version 5.2.1, but we are not sure if we are going to
>> migrate or not.
>> This is what I get:
> I was able to reproduce the problem. I have entered a bug for it [1]
> and prepared patches for different versions of Mapserver. Please check
> the bug and update it if that works for you. As I mentioned, this
> should not happen with current trunk version.
> [1]: http://trac.osgeo.org/mapserver/ticket/3430
> best regards
>> Request:
>> <?xml version="1.0" ?><wfs:GetFeature service="WFS" version="1.1.0"
>> outputFormat="text/xml;
>> subtype=gml/3.1.1"xmlns:wfs="http://www.opengis.net/wfs"
>> xmlns:ogc="http://www.opengis.net/ogc"xmlns:xsi="http://www.w3.org/20
>> 0 1/ XMLSchema-instance"
>> xsi:schemaLocation="http://www.opengis.net/wfs
>> ../wfs/1.1.0/WFS.xsd">
>> <wfs:Query typeName="PoligonosSigpac"> <ogc:Filter> <ogc:Or>
>> <PropertyIsEqualTo><ogc:PropertyName>GID</ogc:PropertyName><Literal>1
>> /L
>> iteral></PropertyIsEqualTo>
>> <PropertyIsEqualTo><ogc:PropertyName>GID</ogc:PropertyName><Literal>6
>> 5
>> Literal></PropertyIsEqualTo>
>> 9
>> 7<
>> /Literal></PropertyIsEqualTo>
>> <PropertyIsEqualTo><ogc:PropertyName>GID</ogc:PropertyName><Literal>2
>> 4
>> 5<
>> </ogc:Or>
>> </ogc:Filter>
>> </wfs:Query>
>> </wfs:GetFeature>
>> Debug info of the request:
>> [Tue Apr 13 14:05:51 2010].39000 CGI Request 1 on process 3408 [Tue
>> Apr 13 14:05:51 2010].54000 msOracleSpatialLayerOpen called with:
>> GEOMETRY FROM (SELECT * FROM GX_SIGPAC_POLIGONOS) USING UNIQUE gid
>> SRID
>> 82337
>> [Tue Apr 13 14:05:51 2010].164000 msOracleSpatialLayerOpen. Shared
>> connection not available. Creating one.
>> msConnPoolRegister(PoligonosSigpac,admcarto/admcarto at ORA10GEX,01C6FA4
>> 8
>> ) [Tue Apr 13 14:05:51 2010].164000 msOracleSpatialLayerFreeItemInfo
>> was called.
>> [Tue Apr 13 14:05:51 2010].164000 msOracleSpatialLayerGetItems was
>> called.
>> [Tue Apr 13 14:05:51 2010].164000 msOracleSpatialLayerInitItemInfo
>> was
>> called.
>> was
>> called.
>> [Tue Apr 13 14:05:51 2010].164000 msOracleSpatialLayerClose was
> called.
>> Layer name: PoligonosSigpac. Layer connection:
>> [Tue Apr 13 14:05:51 2010].164000 msOracleSpatialLayerClose. Cleaning
>> layerinfo handlers.
>> Oracle Cache.
>> [Tue Apr 13 14:05:51 2010].164000 msOracleSpatialLayerClose. Release
>> the Oracle Pool.
>> msConnPoolRelease(PoligonosSigpac,admcarto/admcarto at ORA10GEX,01C6FA48
>> msConnPoolClose(admcarto/admcarto at ORA10GEX,01C6FA48)
>> [Tue Apr 13 14:05:51 2010].164000 msOracleSpatialLayerOpen called
> with:
>> SRID
>> 82337
>> [Tue Apr 13 14:05:51 2010].210000 msOracleSpatialLayerOpen. Shared
>> 8
>> ) [Tue Apr 13 14:05:51 2010].226000 msOracleSpatialLayerFreeItemInfo
>> was called.
>> [Tue Apr 13 14:05:51 2010].226000 msOracleSpatialLayerWhichShapes was
>> called.
>> [Tue Apr 13 14:05:51 2010].226000 msOracleSpatialLayerWhichShapes.
>> Using this Sql to retrieve the data: SELECT gid, GEOMETRY FROM
>> (SELECT
> * FROM
>> GX_SIGPAC_POLIGONOS) WHERE (GID= 1) Or ( (GID= 65) Or ( (GID=
> 197)
>> Or (GID= 245) ) ) AND SDO_FILTER( GEOMETRY,
> MDSYS.SDO_GEOMETRY(2003,
>> 82337,
>> NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,3),MDSYS.SDO_ORDINATE_ARRAY(463
>> 4
>> 98
>> .785,4702415.35,603167.124,4811812.82) ),'querytype=window') = 'TRUE'
>> [Tue Apr 13 14:05:51 2010].257000 msOracleSpatialLayerFreeItemInfo
>> was
>> called.
>> [Tue Apr 13 14:05:51 2010].257000 msOracleSpatialLayerClose was
> called.
>> [Tue Apr 13 14:05:51 2010].257000 msOracleSpatialLayerClose. Cleaning
>> layerinfo handlers.
>> Oracle Cache.
>> [Tue Apr 13 14:05:51 2010].257000 msOracleSpatialLayerClose. Release
>> the Oracle Pool.
>> [Tue Apr 13 14:05:51 2010].288000 msOracleSpatialLayerOpen called
> with:
>> SRID
>> 82337
>> [Tue Apr 13 14:05:51 2010].335000 msOracleSpatialLayerOpen. Shared
>> 8
>> ) [Tue Apr 13 14:05:51 2010].335000 msOracleSpatialLayerFreeItemInfo
>> was called.
>> [Tue Apr 13 14:05:51 2010].335000 msOracleSpatialLayerGetItems was
>> called.
>> [Tue Apr 13 14:05:51 2010].335000 msOracleSpatialLayerInitItemInfo
>> was
>> called.
>> [Tue Apr 13 14:05:51 2010].335000 msOracleSpatialLayerGetShape was
>> called. Using the record = 65.
>> [Tue Apr 13 14:05:51 2010].335000 msOracleSpatialLayerGetShape. Sql:
>> SELECT GID, PROVINCIA, MUNICIPIO, POLIGONO, DN_SURFACE, DN_PERIMET,
>> FECHA_INI, FECHA_FIN, GEOMETRY FROM (SELECT * FROM
>> WHERE gid = 65 AND (GID= 1) Or ( (GID= 65) Or ( (GID= 197) Or
>> (GID= 245) ) )
>> called. Using the record = 1.
>> WHERE gid = 1 AND (GID= 1) Or ( (GID= 65) Or ( (GID= 197) Or
>> (GID= 245) ) )
>> [Tue Apr 13 14:05:51 2010].351000 msOracleSpatialLayerGetShape was
>> called. Using the record = 197.
>> [Tue Apr 13 14:05:51 2010].351000 msOracleSpatialLayerGetShape. Sql:
>> WHERE gid = 197 AND (GID= 1) Or ( (GID= 65) Or ( (GID= 197) Or
>> (GID= 245) ) )
>> called. Using the record = 245.
>> WHERE gid = 245 AND (GID= 1) Or ( (GID= 65) Or ( (GID= 197) Or
>> (GID= 245) ) )
>> [Tue Apr 13 14:05:51 2010].351000 msOracleSpatialLayerFreeItemInfo
>> was
>> called.
>> [Tue Apr 13 14:05:51 2010].351000 msOracleSpatialLayerClose was
> called.
>> [Tue Apr 13 14:05:51 2010].351000 msOracleSpatialLayerClose. Cleaning
>> layerinfo handlers.
>> Oracle Cache.
>> [Tue Apr 13 14:05:51 2010].351000 msOracleSpatialLayerClose. Release
>> the Oracle Pool.
>> [Tue Apr 13 14:05:51 2010].367000 mapserv request processing time
>> (msLoadMap not incl.): 0.328s [Tue Apr 13 14:05:51 2010].367000
>> msFreeMap(): freeing map at 015D5F68.
>> [Tue Apr 13 14:05:51 2010].367000 msOracleSpatialLayerClose was
> called.
>> And the WFS response is
>> <?xml version='1.0' encoding="ISO-8859-1" ?> <wfs:FeatureCollection
>> xmlns:ms="http://mapserver.gis.umn.edu/mapserver"
>> xmlns:gml="http://www.opengis.net/gml"
>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>> xsi:schemaLocation="http://mapserver.gis.umn.edu/mapserver
http://192.168.1.65/cgi-bin/mapserv.exe?map=../htdocs/MFD/ejemplo_wfs.
>> ma
>> p&SERVICE=WFS&VERSION=1.1.0&REQUEST=DescribeFeatureType&a
>> m p; TYPENAME=PoligonosSigpac&OUTPUTFORMAT=text/xml;
>> subtype=gml/3.1.1 http://www.opengis.net/wfs
>> http://schemas.opengis.net/wfs/1.1.0/wfs.xsd">
>> <gml:boundedBy>
>> <gml:Envelope srsName="EPSG:23030">
>> <gml:lowerCorner>507876.512623
>> 4725415.908118</gml:lowerCorner>
>> <gml:upperCorner>559140.632916
>> 4754027.254311</gml:upperCorner>
>> </gml:Envelope>
>> </gml:boundedBy>
>> <gml:featureMember>
>> <ms:PoligonosSigpac gml:id="PoligonosSigpac.65">
>> <gml:boundedBy>
>> <gml:upperCorner>509654.924986
>> 4727430.060275</gml:upperCorner>
>> </gml:Envelope>
>> </gml:boundedBy>
>> <ms:msGeometry>
>> <gml:Polygon srsName="EPSG:23030">
>> <gml:exterior>
>> <gml:LinearRing>
>> <gml:posList srsDimension="2">508370.140478
>> 4727315.545819 508335.867232 4727320.996035 508290.659396
>> 4727330.184342
>> 508247.515061 4727336.285225 508213.831723 4727342.360368
>> 508177.893761
>> 4727350.759952 508139.217777 4727358.067493 508106.542691
>> 4727365.168198
>> 508073.350896 4727379.742591 508042.031529 4727396.059870
>> 508021.380782
>> 4727407.028376 508000.141383 4727416.507020 507972.680877
>> 4727426.806950 507960.779080 4727430.060275 507959.520472
>> 4727426.009949 507955.353514
>> 4727413.672367 507951.761294 4727403.038770 507940.152078
>> 4727366.678616
>> 507937.929127 4727359.369470 507935.747217 4727352.190681
>> 507931.581751
>> 4727338.475568 507925.955179 4727317.629036 507923.366757
>> 4727305.684210
>> 507921.980341 4727299.288189 507919.924662 4727289.763994
>> 507919.501512
>> 4727287.557569 507918.853104 4727284.206032 507917.556317
>> 4727277.475035 507915.993360 4727269.347569 507915.966036
>> 4727269.226537 507909.529718
>> 4727241.919508 507903.103010 4727212.164555 507898.301770
>> 4727189.894905 507893.683300 4727163.865132 507889.994402
>> 4727135.453636 507884.446852
>> 4727105.252936 507880.796683 4727084.976475 507879.258052
>> 4727067.466825
>> 507878.242666 4727054.723344 507877.734988 4727048.337643
>> 507876.512623
>> 4727036.468857 507901.689121 4727031.341055 507926.183367
>> 4727028.446425
>> 507950.525888 4727026.156712 507985.608118 4727022.743920
>> 508015.284939
>> 4727015.052783 508037.247246 4727010.861835 508069.146425
>> 4727005.174678 508092.282870 4727000.994582 508089.277872
>> 4726969.642533 508087.296632
>> 4726943.531951 508091.298917 4726897.081602 508091.919707
>> 4726888.779807
>> 508095.065469 4726846.758955 508095.191947 4726838.419352
>> 508095.297109
>> 4726830.694036 508092.830917 4726814.132651 508089.703848
>> 4726793.158617
>> 508085.562445 4726764.690657 508079.301398 4726740.334254
>> 508071.215454
>> 4726708.734296 508069.656907 4726702.756900 508063.176492
>> 4726678.000025
>> 508053.145208 4726642.227951 508051.852827 4726637.619109
>> 508046.386304 4726597.040250 508038.952405 4726541.743555
>> 508037.000605 4726531.400374
>> 508031.302195 4726501.152871 508023.621785 4726462.842562
>> 508019.804997
>> 4726432.336636 508016.059925 4726405.097817 508015.962530
>> 4726400.257673
>> 508015.308803 4726365.883391 508015.405821 4726335.465775
>> 508014.912053
>> 4726323.057972 508013.470935 4726286.700232 508011.971896
>> 4726229.176607
>> 508026.512006 4726179.071223 508028.904353 4726170.827332
>> 508029.393851
>> 4726169.143198 508052.468188 4726108.567252 508076.090025
>> 4726049.928038
>> 508080.642042 4726038.819900 508081.337592 4726037.117395
>> 508096.646573
>> 4725999.727449 508110.989526 4725966.441124 508111.375126
>> 4725965.548032
>> 508135.743929 4725914.905260 508171.199684 4725844.226772
>> 508189.399434
>> 4725807.873613 508196.585760 4725793.529576 508215.254371
>> 4725790.535992
>> 508231.024486 4725788.004400 508266.390519 4725782.331577
>> 508365.455593
>> 4725766.413314 508384.879769 4725763.402485 508410.519989
>> 4725759.421944
>> 508415.527148 4725758.646178 508455.969121 4725752.366183
>> 508482.986724
>> 4725717.215961 508500.347456 4725694.638053 508549.570764
>> 4725629.125610
>> 508597.013173 4725566.161632 508639.042793 4725510.358187
>> 508661.455261
>> 4725479.819566 508685.813878 4725447.338141 508698.078900
>> 4725431.269762 508709.807420 4725415.908118 508711.487492
>> 4725417.883472 508733.088271
>> 4725443.330116 508756.273369 4725470.295994 508777.245610
>> 4725492.903124
>> 508802.260121 4725517.507312 508825.441333 4725541.727637
>> 508843.070387
>> 4725557.629135 508859.256350 4725568.828423 508874.812880
>> 4725578.137470
>> 508892.829081 4725586.528245 508911.747862 4725592.593292
>> 508928.211276
>> 4725596.179365 508947.038186 4725598.893604 508971.631261
>> 4725603.486218
>> 508999.339589 4725610.009670 509019.870954 4725616.914807
>> 509041.116605
>> 4725623.727859 509053.963702 4725625.075653 509067.102026
>> 4725624.283070
>> 509089.336347 4725620.756662 509113.982155 4725616.460957
>> 509140.307380
>> 4725614.531722 509153.526752 4725614.791186 509157.138904
>> 4725614.861116
>> 509167.618268 4725615.061137 509168.462930 4725615.080871
>> 509169.966848
>> 4725615.110786 509172.109418 4725615.150854 509180.137179
>> 4725615.310417
>> 509186.276462 4725615.430251 509205.415827 4725615.455669
>> 509214.659310
>> 4725615.467964 509228.463752 4725619.870295 509245.908707
>> 4725628.801078
>> 509266.850646 4725641.710991 509286.002956 4725657.634278
>> 509307.178433 4725680.606300 509330.024251 4725712.488152
>> 509356.982911 4725744.692101
>> 509386.382826 4725774.209528 509409.755112 4725802.238955
>> 509426.577993
>> 4725823.706889 509447.670860 4725851.146957 509460.888344
>> 4725872.554211
>> 509474.960082 4725896.922525 509489.527443 4725925.359035
>> 509501.304870
>> 4725950.096571 509516.172709 4725984.583590 509526.792406
>> 4726012.139830
>> 509540.353888 4726042.641390 509551.154943 4726068.019906
>> 509557.839801 4726090.479430 509561.384907 4726109.081215
>> 509564.069424 4726124.312406
>> 509564.459679 4726140.061664 509563.434889 4726161.123694
>> 509563.562161
>> 4726183.322863 509562.440193 4726210.118337 509562.503494
>> 4726238.860770
>> 509562.431992 4726260.799050 509564.975677 4726278.515222
>> 509568.175738 4726293.300360 509574.010192 4726314.790726
>> 509582.411063 4726337.494658
>> 509588.746614 4726354.089853 509590.306503 4726373.079837
>> 509588.785093
>> 4726395.714195 509589.159036 4726428.142939 509586.513898
>> 4726468.897948
>> 509580.573918 4726498.972400 509573.997242 4726532.685311
>> 509573.068354
>> 4726558.894677 509575.920317 4726586.952209 509572.188843
>> 4726628.850585
>> 509577.842121 4726666.927146 509582.722965 4726692.539553
>> 509584.190067
>> 4726728.907009 509594.120718 4726772.043630 509603.691208
>> 4726797.541556
>> 509614.372955 4726828.700161 509624.999798 4726854.832516
>> 509636.123603
>> 4726879.038872 509645.984773 4726902.666407 509654.924986
>> 4726936.735984
>> 509633.800419 4726939.982883 509615.464111 4726942.786946
>> 509610.608762
>> 4726943.534132 509591.104806 4726946.653103 509545.242065
>> 4726954.743305
>> 509500.390426 4726961.606574 509497.354986 4726962.077105
>> 509435.379554
>> 4726973.962128 509417.054136 4726978.981980 509410.081899
>> 4726981.345977
>> 509377.700548 4726992.331730 509329.754895 4727007.792288
>> 509320.449810
>> 4727009.017684 509313.575740 4727009.911284 509290.453359
>> 4727023.534700 509246.101320 4727047.554498 509207.617401
>> 4727068.343281 509164.381481 4727089.898530 509126.277006
>> 4727109.673721 509090.098268 4727132.337059
>> 509067.768835 4727149.275826 509058.801415 4727160.228632
>> 509043.970678
>> 4727181.626407 509041.508058 4727185.188064 509023.025734
>> 4727211.151228
>> 509012.704374 4727218.006912 508979.662832 4727236.458496
>> 508957.605756
>> 4727250.317101 508956.849909 4727250.790819 508945.237337
>> 4727258.091705
>> 508943.616432 4727258.545691 508937.242692 4727260.343164
>> 508930.999465
>> 4727262.094273 508920.106433 4727265.161095 508877.586291
>> 4727276.312974
>> 508840.171674 4727284.213916 508836.024080 4727284.757777
>> 508803.990153
>> 4727288.933371 508767.495442 4727291.614218 508746.759555
>> 4727292.732835
>> 508712.381656 4727293.722635 508668.513405 4727296.264416
>> 508636.606992 4727297.415920 508604.852191 4727298.120986
>> 508564.557869 4727297.680078
>> 508531.128179 4727298.113485 508492.603378 4727299.164420
>> 508458.641561
>> 4727302.445701 508425.942066 4727306.547768 508385.948362
>> 4727313.023936
>> 508370.140478 4727315.545819 </gml:posList>
>> </gml:LinearRing>
>> </gml:exterior>
>> </gml:Polygon>
>> </ms:msGeometry>
>> </ms:PoligonosSigpac>
>> </gml:featureMember>
>> <gml:featureMember>
>> <ms:PoligonosSigpac gml:id="PoligonosSigpac.1">
>> <gml:boundedBy>
>> <gml:lowerCorner>529575.602797
>> 4753999.660256</gml:lowerCorner>
>> <gml:upperCorner>529612.280989
>> </gml:Envelope>
>> </gml:boundedBy>
>> <ms:msGeometry>
>> <gml:exterior>
>> <gml:LinearRing>
>> <gml:posList srsDimension="2">529580.641695
>> 4754027.254311 529578.565694 4754018.588615 529575.602797
>> 4754006.232999
>> 529577.786673 4754005.739761 529605.580625 4753999.660256
>> 529607.454087
>> 4754004.536595 529608.306230 4754006.764963 529609.983399
>> 4754011.165731
>> 529610.151849 4754011.752883 529611.822510 4754017.661573
>> 529612.280989
>> 4754019.190118 529580.641695 4754027.254311 </gml:posList>
>> </gml:LinearRing>
>> </gml:exterior>
>> </gml:Polygon>
>> </ms:msGeometry>
>> <gml:featureMember>
>> <gml:boundedBy>
>> </gml:Envelope>
>> </gml:boundedBy>
>> <ms:msGeometry>
>> <gml:exterior>
>> <gml:LinearRing>
>> 4727330.184342
>> 508177.893761
>> 4727365.168198
>> 508021.380782
>> 4727366.678616
>> 507931.581751
>> 4727305.684210
>> 507919.501512
>> 4727067.466825
>> 507876.512623
>> 4727028.446425
>> 508015.284939
>> 4726888.779807
>> 508095.297109
>> 4726793.158617
>> 508071.215454
>> 4726678.000025
>> 508019.804997
>> 4726400.257673
>> 508014.912053
>> 4726229.176607
>> 508029.393851
>> 4726049.928038
>> 508096.646573
>> 4725965.548032
>> 508189.399434
>> 4725790.535992
>> 508365.455593
>> 4725759.421944
>> 508482.986724
>> 4725629.125610
>> 508661.455261
>> 4725492.903124
>> 508843.070387
>> 4725578.137470
>> 508928.211276
>> 4725603.486218
>> 509041.116605
>> 4725624.283070
>> 509140.307380
>> 4725614.861116
>> 509169.966848
>> 4725615.310417
>> 509214.659310
>> 4725628.801078
>> 509426.577993
>> 4725872.554211
>> 509501.304870
>> 4726012.139830
>> 509563.562161
>> 4726238.860770
>> 509588.785093
>> 4726468.897948
>> 509573.068354
>> 4726628.850585
>> 509584.190067
>> 4726797.541556
>> 509636.123603
>> 4726936.735984
>> 509610.608762
>> 4726954.743305
>> 509435.379554
>> 4726981.345977
>> 509320.449810
>> 509043.970678
>> 4727211.151228
>> 508957.605756
>> 4727258.091705
>> 508930.999465
>> 4727276.312974
>> 508803.990153
>> 4727292.732835
>> 508458.641561
>> 4727313.023936
>> </gml:LinearRing>
>> </gml:exterior>
>> </gml:Polygon>
>> </ms:msGeometry>
>> <gml:featureMember>
>> <gml:boundedBy>
>> </gml:Envelope>
>> </gml:boundedBy>
>> <ms:msGeometry>
>> <gml:exterior>
>> <gml:LinearRing>
>> 4727330.184342
>> 508177.893761
>> 4727365.168198
>> 508021.380782
>> 4727366.678616
>> 507931.581751
>> 4727305.684210
>> 507919.501512
>> 4727067.466825
>> 507876.512623
>> 4727028.446425
>> 508015.284939
>> 4726888.779807
>> 508095.297109
>> 4726793.158617
>> 508071.215454
>> 4726678.000025
>> 508019.804997
>> 4726400.257673
>> 508014.912053
>> 4726229.176607
>> 508029.393851
>> 4726049.928038
>> 508096.646573
>> 4725965.548032
>> 508189.399434
>> 4725790.535992
>> 508365.455593
>> 4725759.421944
>> 508482.986724
>> 4725629.125610
>> 508661.455261
>> 4725492.903124
>> 508843.070387
>> 4725578.137470
>> 508928.211276
>> 4725603.486218
>> 509041.116605
>> 4725624.283070
>> 509140.307380
>> 4725614.861116
>> 509169.966848
>> 4725615.310417
>> 509214.659310
>> 4725628.801078
>> 509426.577993
>> 4725872.554211
>> 509501.304870
>> 4726012.139830
>> 509563.562161
>> 4726238.860770
>> 509588.785093
>> 4726468.897948
>> 509573.068354
>> 4726628.850585
>> 509584.190067
>> 4726797.541556
>> 509636.123603
>> 4726936.735984
>> 509610.608762
>> 4726954.743305
>> 509435.379554
>> 4726981.345977
>> 509320.449810
>> 509043.970678
>> 4727211.151228
>> 508957.605756
>> 4727258.091705
>> 508930.999465
>> 4727276.312974
>> 508803.990153
>> 4727292.732835
>> 508458.641561
>> 4727313.023936
>> </gml:LinearRing>
>> </gml:exterior>
>> </gml:Polygon>
>> </ms:msGeometry>
>> </wfs:FeatureCollection>
>> martes, 13 de abril de 2010 13:09
>> David,
>>> Assefa,
>>> Thanks for your response. I had that configured in the waye you told
>> me this is what I get:
>>> [Fri Apr 09 11:24:45 2010].725000 CGI Request 1 on process 1948 [Fri
>> Apr 09 11:24:46 2010].37000 mapserv request processing time
>> (msLoadMap
>> not incl.): 0.312s [Fri Apr 09 11:24:46 2010].37000 msFreeMap():
>> freeing map at 015D60B8.
>>>> You should be able to check then the query sent to the oracle db
>>>> and
>> that might give your more hints.
>>> Where I can view the query sent to Oracle??
>>> Thanks.
>> I forgot to mention that you also need to have the debug statement
>> in
>> your layer for layer specific debug output in oracle.
>> Layer
>> DEBUG 5
>> END
>> I am not sure what version of MapServer your are using, but you
>> should
>> if not already (and possiible) upgrade to 5.6.3 or the trunk version
>> from svn. Both have a lot more debugging information for the oracle
>> spatial.
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Assefa Yewondwossen
> Software Analyst
> Email: yassefa at dmsolutions.ca
> http://www.dmsolutions.ca/
> Phone: (613) 565-5056 (ext 14)
> Fax: (613) 565-0925
Assefa Yewondwossen
Software Analyst
Fax: (613) 565-0925
