[mapserver-users] Strange Behaviour with getFeature using POST method and more than one typename
David Alda Fernandez de Lezea dalda at ikt.es
Wed Apr 14 06:00:20 EDT 2010
Assefa,
> From the url you sent, you seem to  be on a windows machine, is that
correct?
Yes, I'm currently on a windows machine. I've got ms4w package (MS4W
Base Installer v2.3.1 (Dec 2, 2008) to be precise)
>  I am trying to see if it is possible to provide you binaries
with the patch. I can provide this service for a fee myself or though an
associate.
Does this mean that I have to pay to get the binaries with the patch?
We are planning to to get this working in production level, so it would
be desirable to have a stable version of MapServer. What would you
recommend as best (not too much complicated and short in time) solution?
Thanks.
-----Mensaje original-----
De: Yewondwossen Assefa [mailto:yassefa at dmsolutions.ca]
Enviado el: martes, 13 de abril de 2010 18:42
Para: David Alda Fernandez de Lezea
Asunto: Re: [mapserver-users] Strange Behaviour with getFeature using
POSTmethod and more than one typename
David Alda Fernandez de Lezea wrote:
> Assefa,
> Thanks one more time. I hope this will be a strong reason to migrate
> to the latest version. Until that happens, I don't know really how I
> have to proceed to update my mapserver version with this patch. Should
> I re-compile the application?? How should I proceed??
 Yes you need to recompile or get binaries that has the patch.  From the
url you sent, you seem to  be on a windows machine, is that correct? If
that is the case, where did you get your binaries (ms4w, other
sources)?   I am trying to see if it is possible to provide you binaries
associate.
Let me know.
best regards,
