[mapserver-users] mapserver as a tiling client for an untiled WMS
Smith, Michael ERDC-CRREL-NH michael.smith at usace.army.mil
Sun Apr 18 17:39:17 EDT 2010
Marco,
  Correct, these will just be regular WMS requests and GDAL will stitch them
together. If you enable the cache, the images can be cached locally.
Mike
Michael Smith
RSGIS Center
US Army Corps of Engineers
On 4/18/10 3:04 PM, "DeDuikertjes" <DeDuikertjes at xs4all.nl> wrote:
> Michael,
> Thank you.
> Do I understand correctly that this GDAL WMS Minidriver with this xml
> file for a given map area (bounding box) will do a series of "normal"
> WMS requests (as opposed to "tiled" WMS requests) to the server to
> obtain a set of tiles which will be stitched together and incorporated
> in the map?
> MArco
> Smith, Michael ERDC-CRREL-NH schreef:
>> Marco,
>> To use the GDAL WMS Minidriver, create an XML file like below and then
>> reference that xml file in your MapServer layer. For more info about the
>> format of the WMS xml, see here http://www.gdal.org/frmt_wms.html
>> Example xml
>> <GDAL_WMS>
>>   <Service name="WMS">
>>       <Version>1.1.1</Version>
>>  <ServerUrl>http://hazards.fema.gov/wmsconnector/wmsconnector/com.esri.wms.E
>> srimap/NFHL?transparent=true&</ServerUrl>
>>         <SRS>EPSG:4326</SRS>
>>         <Layers>Flood_Hazard_Zones_General</Layers>
>>         <Styles>default</Styles>
>>         <ImageFormat>image/gif</ImageFormat>
>>     </Service>
>>     <DataWindow>
>>         <UpperLeftX>-180.0</UpperLeftX>
>>         <UpperLeftY>90.0</UpperLeftY>
>>         <LowerRightX>180.0</LowerRightX>
>>         <LowerRightY>-90.0</LowerRightY>
>>         <TileLevel>19</TileLevel>
>>         <TileCountX>2</TileCountX>
>>         <TileCountY>1</TileCountY>
>>     </DataWindow>
>>     <Projection>EPSG:4326</Projection>
>>     <BlockSizeX>1024</BlockSizeX>
>>     <BlockSizeY>1024</BlockSizeY>
>>     <BandsCount>3</BandsCount>
>>      <Cache>
>>         <Path>/htdocs/orm/gdalwmscache</Path>
>>         <Depth>2</Depth>
>>         <Extension>.gif</Extension>
>>      </Cache>
>>   <AdviseRead>true</AdviseRead>
>>   <VerifyAdviseRead>true</VerifyAdviseRead>
>> </GDAL_WMS>
>> Mapfile section
>> LAYER
>>   NAME femaq3
>>   DATA "/data/fema/fema_gen_wms.xml"
>>   OFFSITE 255 255 255
>>   TYPE raster
>>   STATUS off
>>   PROJECTION
>>     "proj=latlong"
>>     "ellps=GRS80"
>>   END
>>   CLASS
>>       NAME "100 year floodplain"
>>       SYMBOL 0
>>     COLOR 255 0 0
>>   END
>>   CLASS
>>       NAME "500 year floodplain"
>>       SYMBOL 0
>>     COLOR 255 192 203
>>   END
>> END
