[mapserver-users] Re: mapserver as a tiling client for an untiled
WMS
deduikertjes
DeDuikertjes at xs4all.nl
Wed Apr 21 13:30:52 EDT 2010
So I've tried for real.
First I created a WMS to act as the untiled WMS which I wanted to access.
Then I created a mapfile which consumes this WMS, and a client to view the
results. Everything OK. The client shows the map as it should be.
The layer defintion to consume the WMS:
LAYER
NAME "my_untiled_WMS"
TYPE RASTER
STATUS off
CONNECTIONTYPE WMS
CONNECTION "http://my_untiled_WMS_url"
METADATA
"wms_srs" "EPSG:28992"
"wms_name" "my_root_layer"
"wms_server_version" "1.1.1"
"wms_format" "image/png"
"wms_exceptions_format" "application/vnd.ogc.se_xml"
END
DEBUG 5
END
Then I replaced this LAYER definition by things like:
LAYER
DEBUG 5
PROJECTION
"init=epsg:28992"
END
TYPE RASTER
STATUS off
DATA "/var/www/html/tmp/test.xml"
EXTENT 102790.553 430082.85 182959.978 487853.15
OFFSITE 0 0 0
METADATA
"wms_title" "my_root_layer"
"wms_extent" "102790.553 430082.85 182959.978 487853.15"
END
PROCESSING "CLOSE_CONNECTION=DEFER"
END
Test XML being things like:
<GDAL_WMS>
<Service name="WMS">
<Version>1.1.1</Version>
<ServerUrl>http://my_untiled_WMS_url</ServerUrl>
<SRS>EPSG:28992</SRS>
<Layers>my_root_layer</Layers>
<Styles>default</Styles>
<ImageFormat>image/png</ImageFormat>
</Service>
<DataWindow>
<UpperLeftX>10528</UpperLeftX> <!--minx from the
capabilities of my_untiled_wms -->
<UpperLeftY>621876</UpperLeftY> <!--maxy from the capabilities
<LowerRightX>278026</LowerRightX> <!--maxx from the capabilities
<LowerRightY>306839</LowerRightY> <!--miny from the capabilities
<SizeX>1000</SizeX> <!-- This is the
size limit of my_untiled_wms -->
<SizeY>1000</SizeY> <!-- This is the
</DataWindow>
<Projection>EPSG:28992</Projection>
<BlockSizeX>1000</BlockSizeX> <!-- not sure, need not set,
or set to 1000? -->
<BlockSizeY>1000</BlockSizeY> <!-- not sure, need not set,
or set to 1000? -->
<BandsCount>3</BandsCount>
<AdviseRead>true</AdviseRead>
<VerifyAdviseRead>true</VerifyAdviseRead>
</GDAL_WMS>
I tweaked a lot of the parameters but whatever I do I only get pink tiles
(no images). So I checked the error logs (debug 5). No errors at all. The
error log of the untiled WMS (http://my_untiled_WMS_url) shows that this WMS
never gets accessed.
So I wonder, is this minidriver working at all? Is it testable or
debug-able? How should I proceed. I'm really at loss.
Any help greatly appreciated.
View this message in context: http://n2.nabble.com/mapserver-as-a-tiling-client-for-an-untiled-WMS-tp4917136p4938381.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
