[mapserver-users] Re: Mapscript c# VS 2010 framework 4 and memory
leaks
Tamas Szekeres
szekerest at gmail.com
Thu Apr 22 09:54:10 EDT 2010
2010/4/22 James Perrins <JamesP at esdm.co.uk>
> However - unfortunately after all this - it doesn't seem to make any
> difference to the original problems with the memory errors. I had hoped by
> compiling to CLR 4 these would go but they haven't. So I'm back to square
> one - it doesn't work with CLR 4.
> Any other ideas whey there might be memory issues ?
I suspect it may be due to the fact that many dependent dll-s may refer to
different CRT libraries since multiple compilers have been used. For more
information about this topic see my related blogpost: Redistribution of the
shared C runtime component in Visual
C++<http://szekerest.blogspot.com/2010/02/redistribution-of-shared-c-runtime.html>
It would be reasonable to test with a consistent build, where all the
dependecies have been compiled with the same compiler. I'll be trying to
extend the SDK packages <http://vbkto.dyndns.org/sdk/> with the VS2010
versions soon.
Best regards,
Tamas
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100422/5c462efd/attachment.html
