[mapserver-users] Re: gdalinfo - error while opening CADRG map
wostok
wostok at o2.pl
Wed Apr 28 06:29:00 EDT 2010
Even, thanks for your reply. I managed to build my own gdal dll with removed
lines in gdal/frmts/nitf/rpftocfile.cpp, and everything seems to be all
right. CADRG map loaded without problems and it looks fine.
Unfortunately I am not allowed to send you a copy of my dataset.
Thank you very much.
Please reply if you need more feedback.
wostok
Even Rouault wrote:
> wostok,
> I'd think that such a TOC file would be invalid. It would mean that the
> same
> CADRG tile is used several times at different geolocations. But as a CADRG
> tile contains its own georeferencing, this doesn't make much sense.
> However, if you can compile gdal yourself, you could remove the following
> lines (around line 423-430) in gdal/frmts/nitf/rpftocfile.cpp and see what
> happens.
> if (frameEntry->exists)
> CPLError( CE_Failure, CPLE_NotSupported,
> "Invalid TOC file. Frame entry(%d,%d) for frame file
> index %d is a duplicate.",
> frameRow, frameCol, i);
> RPFTOCFree(toc);
> return NULL;
> I'd be interested in having your feedback and/or seeing this dataset if
> you
> can share it. Maybe this test should just be turned into a warning.
> Best regards,
> Even
> Le Tuesday 20 April 2010 14:33:10 wostok, vous avez écrit :
>> Hello,
>> I'm getting error while executing gdalinfo on CADRG map (.toc file):
>> gdalinfo.exe my_toc_file.toc
>> ERROR 6: Invalid TOC file. Frame entry(15,6) for frame file index 421 is
>> a
>> duplicate.
>> gdalinfo failed - unable to open 'path_to_A.TOC'.
>> It looks like the map file is bad, but when I opened it in CADRG viewer -
>> Tatuk Gis,
>> there weren't any problems.
>> I haven't found any information about this error on google.
>> Is this a bug or my map file has been corrupted?
>> I use fwtools 2.4.7 on win xp,
>> Thanks in advance.
>> wostok
> mapserver-users at lists.osgeo.org
View this message in context: http://osgeo-org.1803224.n2.nabble.com/gdalinfo-error-while-opening-CADRG-map-tp4930886p4973736.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
