[mapserver-users] Disregard ECW header for TFW in TILEINDEX ?
Lars I. Nielsen (GisPro)
LIN at gispro.dk
Wed Apr 28 08:33:51 EDT 2010
Hi Jukka,
Alas, it doesn't, or it doesn't work.
I made a copy of the errornous ECW file, and edited the header. The
original doesn't display, while the edited does (perfectly so), with the
exact same mapping file.
Adding the PROCESSING directive doesn't help, the errornous ECW file
still doesn't show. And I'm sure that the TFW is both present and
correct :-)
The debug log reports: msResampleGDALToMap(): no overlap ... no result.
The errornous ECW header setting tells GDAL that the Y axis is
downwards, not upwards. And it has UL=(0,0) and dx,dy = 1,1. I.e. dummy
data.
Is GDAL still reading the (here errornous) Y axis direction setting
although it shouldn't (with the directive in place) ?
Best regards / Med venlig hilsen
Lars I. Nielsen
GIS & DB Integrator
GisPro
Rahkonen Jukka skrev:
> Hi,
> I believe that version 5.2.1 supports setting EXTENT_PRIORITY. Read http://lists.osgeo.org/pipermail/mapserver-users/2008-October/058227.html
> -Jukka Rahkonen-
> Lars I. Nielsen wrote:
>> Hi Frank,
>> This may work, but I'm unable to test it, since I'm currently unable to
> retrieve anything newer than 5.2.1 (included in the latest ms4w.zip).
> There's a newer version 5.7beta of Mapserver included in the FWTools
> package, but the DLL set it uses seems totally different from the one
> used in cgi-bin in the ms4w package.
>> Please advise as to how I can download a newer version of Mapserver.
>> Cheers.
>> Lars I. Nielsen
>> GIS & DB Integrator
> GisPro
> Frank Warmerdam skrev:
>> Lars I. Nielsen (GisPro) wrote:
>>> Hi,
>>> I'm trying to set up Mapserver as a WMS server, serving multiple
>>> seamless coverages consisting of ECW raster tiles.
>>> My problem is, that the ECW files have been delivered with faulty
>>> header information, and there's too many to fix manually, and the
>>> error cannot easily be remedied programmatically.
>>> However, I have generated TFW files for each tile that are correct,
>>> but how do I force Mapserver to use the TFW files and disregard the
>>> faulty ECW header ?
>> Lars,
>> As it happens this is not a unique situation and MapServer itself has
>> some
>> logic to address it. If you add:
>> PROCESSING "EXTENT_PRIORITY=WORLD"
>> to your layer definition, then world files will be searched for in
>> preference
>> to using the georeferencing returned by GDAL. I'm not sure exactly
>> when this
>> was incorporated but I imagine it is in 5.4 and later. Also the file
>> extension
>> should likely be either .eww or .wld, not .tfw for ecw files.
>> Best regards,
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100428/27733c7e/attachment.html
