[mapserver-users] Disregard ECW header for TFW in TILEINDEX ?
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Wed Apr 28 09:36:41 EDT 2010
Hi Lars,
You should have read the link I sent for you :) Here is an excerpt:
"Yes, it should work, though looking at the code it only looks for world
files with the extension .wld in this case (not .tfw, or .tifw). The code
is:"
So this piece of code that Frank kindly made when I asked if it could be possible to override georeferencing info of geotiffs and use world files instead is looking just for .wld files. Generally gdal does not behave this way.
-Jukka-
-----Alkuperäinen viesti-----
Lähettäjä: mapserver-users-bounces at lists.osgeo.org puolesta: Frank Warmerdam
Lähetetty: ke 28.4.2010 16:28
Vastaanottaja: LIN at gispro.dk
Kopio: mapserver-users at lists.osgeo.org
Aihe: Re: [mapserver-users] Disregard ECW header for TFW in TILEINDEX ?
Lars I. Nielsen (GisPro) wrote:
> Hi Richard,
> Ah, Mapserver and/or GDAL doesn't support the TFW extension anymore ?
> Didn't know that. When did this happen ?
> Renaming the TFW to WLD did the trick, now the ECW displays nicely.
Lars,
As far as I know the .tfw extension was only ever for tiff files. The
rule for worldfiles is that you take the first and last letter of the
regular extension and add a w to make the three letter world file
extension for the target file.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
