[mapserver-users] Disregard ECW header for TFW in TILEINDEX ?
Lars I. Nielsen (GisPro) LIN at gispro.dk
Wed Apr 28 09:50:01 EDT 2010
Hi Jukka,
Right you are, I just assumed the link was to a post wrt. version 5.2.1.
I probably wouldn't have noticed the extension issue anyway ,-)
Goes to show, I _have_ been away from Mapserver for too long :-)
Best regards / Med venlig hilsen
Lars I. Nielsen
GIS & DB Integrator
GisPro
Rahkonen Jukka skrev:
> Hi Lars,
> You should have read the link I sent for you :) Here is an excerpt:
> "Yes, it should work, though looking at the code it only looks for world
> files with the extension .wld in this case (not .tfw, or .tifw).  The code
> is:"
> So this piece of code that Frank kindly made when I asked if it could be possible to override georeferencing info of geotiffs and use world files instead is looking just for .wld files. Generally gdal does not behave this way.
> -Jukka-
> -----Alkuperäinen viesti-----
> Lähettäjä: mapserver-users-bounces at lists.osgeo.org puolesta: Frank Warmerdam
> Lähetetty: ke 28.4.2010 16:28
> Vastaanottaja: LIN at gispro.dk
> Kopio: mapserver-users at lists.osgeo.org
> Aihe: Re: [mapserver-users] Disregard ECW header for TFW in TILEINDEX ?
> Lars I. Nielsen (GisPro) wrote:
>> Hi Richard,
>> Ah, Mapserver and/or GDAL doesn't support the TFW extension anymore ?
>> Didn't know that. When did this happen ?
>> Renaming the TFW to WLD did the trick, now the ECW displays nicely.
> Lars,
> As far as I know the .tfw extension was only ever for tiff files.  The
> rule for worldfiles is that you take the first and last letter of the
> regular extension and add a w to make the three letter world file
> extension for the target file.
> Best regards,
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100428/fad74aa2/attachment.html
