[mapserver-users] Re: Invalid Layer(s) in Layer parameter
Tonton to.tonton at gmail.com
Thu Apr 29 10:53:21 EDT 2010
> Hello
> i try to make WebMapping with mapserver/Openlayer
> i meet some trouble with projection and extent  because i have blank map in
> Qgis request
> it is working on SIS cardcorp
> *with getmap request *
> http://geomap/cgi-bin/mapserv?map=/var/www/geomod/test.map&SERVICE=WMS&VERSION=
> *1.1.1*&REQUEST=GetMap&LAYERS=Parcelles :
> <ServiceExceptionReport version="1.1.1">−
> <ServiceException code="MissingParameterValue">
> msWMSLoadGetMapParams(): WMS server error. *Missing required parameter SRS
> </ServiceException>
> </ServiceExceptionReport>
> *1.3.0*&REQUEST=GetMap&LAYERS=Parcelles :
> <ServiceExceptionReport version="1.3.0" xsi:schemaLocation="
> http://www.opengis.net/ogc
> http://schemas.opengis.net/wms/1.3.0/exceptions_1_3_0.xsd">−
> msWMSLoadGetMapParams(): WMS server error. *Missing required parameter CRS
> </ServiceException>
> *in openlayer:*
> WMS server error Invalid Layer(s) given in LAYER parameter
> May be i forgot somthing to define in my web or layer Object ?
> *This is ma web object *
>  WEB
>         MINSCALEDENOM 1000
>         MAXSCALEDENOM 1550000
>         #Modifier cette ligne selon votre installation
>         IMAGEPATH "/var/www/geomod/tmp/"
>         IMAGEURL "./tmp/"
>         METADATA
>         WMS_TITLE "WMS Geomod default Title "
>         WMS_ABSTRACT "Wms Geomod default Description "
>         WMS_ACCESSCONSTRAINTS "None"
>         WMS_ONLINERESOURCE "
> http://192.168.12.109/cgi-bin/mapserv?map=/var/www/geomod/test.map"
>         "WMS_SRS" "EPSG:27572"
>         END
>         LOG "./tmp/web.log"
> END #WEB
> *this is my  layer  *
> LAYER
>         NAME "Parcelles"
>         DATA "parcelles.shp"
>         TYPE POLYGON
> PROJECTION
>         "init=EPSG:27572"
> END #Projection
>         METADATA
>         WMS_TITLE "Parcelles"
>         END
> CLASS
> NAME "Parcelles"
>         STYLE
>         SYMBOL 0
>         SIZE 2
>         OUTLINECOLOR 0 0 0
>         COLOR 255 255 0
>         END
>         END
> END #Layer
> thanks for your help
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100429/db3dd368/attachment.html
