[mapserver-users] Re: WMS and tiles cutting off
thomas bonfort thomas.bonfort at gmail.com
Fri Apr 30 07:28:55 EDT 2010
I usually find that an untiled openlayers wms layer with
transitionEffect:resize has a pretty similar effect that that of a
tiled layer, as the map isn't hidden as soon as the user stops
panning, but is replaced with the new image once that one arrives.
YMMV.
regards,
thomas
On Thu, Apr 29, 2010 at 21:25, Adam Eskreis <aeskreis at gmail.com> wrote:
> Ok, I just gave an untiled layer a try, unfortunately though, due to the
> large amount of symbols being displayed on the screen, there is about a 2
> second delay every time the map is panned.  My client will most certainly
> find this unacceptable.  I have tried using smaller images, but I cannot
> sacrifice any more quality.  I believe my database query to be as optimized
> as it can be (has about 50 ms runtime, I honestly don't think I can get it
> any lower than that).
> If these are the only options, is there something else besides WMS that you
> all would recommend using to solve this issue?
> Thanks,
> -Adam
> On Thu, Apr 29, 2010 at 2:54 PM, Lime, Steve D (DNR)
> <Steve.Lime at state.mn.us> wrote:
>> So use two layers. One for the background, use tilecache for that. Then
>> use an untiled wms/mapserver layer for the overlayed points. - Steve
>> ________________________________________
>> From: mapserver-users-bounces at lists.osgeo.org
>> [mapserver-users-bounces at lists.osgeo.org] On Behalf Of Adam Eskreis
>> [aeskreis at gmail.com]
>> Sent: Thursday, April 29, 2010 1:24 PM
>> To: mapserver-users at lists.osgeo.org
>> Subject: Re: [mapserver-users] Re: WMS and tiles cutting off
>> I have thought about using tilecache with metatiling, however there is a
>> caveat about this map that i forgot to mention in my main post, and it has
>> to do with that "categories" parameter.  Basically, each point/symbol on the
>> map has an associated category in the database backend.  I am using
>> mapserver/WMS parameters to change the categories which are called.  Each
>> time the user selects a category, only the points in that category are
>> shown.  My query in the mapfile looks something like thi:
>> SELECT point_geom,gid,symbol,angle FROM mapdata WHERE category
>> IN(%CATEGORIES%)";
>> And each time the user changes the categories, I use openlayers to merge
>> new parameters, and input the new category values that should be used.  Is
>> tilecache still useable if I have a system like this set up?
>> Thanks,
>> -Adam
>> On Thu, Apr 29, 2010 at 6:14 AM, kaipi
>> <mapcollect at gmx.net<mailto:mapcollect at gmx.net>> wrote:
>> Hi,
>> you can use  http://tilecache.org/ Tilecache   with the option metatiling
>> enabled. With metatiling enabled Tilecache will fetch larger tiles (eg.
>> 4096x4096) from Mapserver and will cut them into smaller tiles (eg.
>> 256x256). It will also increase performance because Mapserver does not
>> need
>> to render tiles when they are already in cache.
>> kaipi
>> View this message in context:
>> http://osgeo-org.1803224.n2.nabble.com/WMS-and-tiles-cutting-off-tp4978418p4979280.html
>> Sent from the Mapserver - User mailing list archive at Nabble.com.
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
