[mapserver-users] Re: WMS and tiles cutting off
christopher.schmidt at nokia.com christopher.schmidt at nokia.com
Fri Apr 30 08:50:16 EDT 2010
On Apr 29, 2010, at 5:23 PM, ext Adam Eskreis wrote:
> I tried doing ratio:1 unfortunately it doesn't seem like enough of a performance increase.  Separate layers for each category is an option, however, there are over a hundred categories, and any combination of categories can be on at any given time, so this could prove to have performance issues of it's own.  However, I thank you guys Steve and Kaipi for your advice.  I think I am just going to go back to my old method, which was using php mapscript to generate the tiles, then each time the user selected new categories, purge the cache and remake the mapfile.  It's not the ideal solution but it seems to be the only one.
Haven't really followed this thread, but if your problem is that the map goes "blank" when they drag, untiled, combined with the transitionEffect: 'resize' option will cause the map that you already have to not disappear after a drag.
Just a thought.
-- Chris
