[mapserver-users] vector pdf output
Yewondwossen Assefa
yassefa at dmsolutions.ca
Wed Aug 4 16:39:54 EDT 2010
On 03/08/2010 5:03 PM, Worth Lutz wrote:
> Does MapServer support vector PDF output??
> Also I am experimenting on ver. 5.6.3 with pdf output and am getting
> some output but it does not look like the png output. I also have not
> yet figured out why I sometimes get nothing for some layers. Still
> experimenting...
> Can anyone point me to some examples?
> Is the cairo/pdf output available in the svn trunk? If I compile that
> will I be able to experiment with it? Any advise on trying that?
If you want to experiment, you should try using the version in the
sandbox (http://svn.osgeo.org/mapserver/sandbox/mapserver6/), instead of
trunk. This sandbox will eventually be merged to trunk Ii uses the
cairo library for the pdf output From what I can see, It seems to be in
a good shape. Note that the imagetype to use is pdf.
You can see an example of a pdf generated at
http://www3.dmsolutions.ca/tmp/gmap-ms60.pdf
best regards,
Assefa Yewondwossen
Software Analyst
Email: yassefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100804/6ba96d60/attachment.html
