[mapserver-users] Re: Mapfile multiple CLASSITEM's
Donatas Malinauskas donatas.malinauskas at lgt.lt
Mon Aug 9 08:16:39 EDT 2010
Yes, Sumit, I understand - with few classes I can describe different
animals, but the problem is that the same PIG in the map should be in
severel different colours. The column value (eg. big pig - fills white,
biggest pig - fills yellow, very big pig - fills red and so on) I read
from data table...Is it possible to fill the same PIG ( in the same
class) in different colours depending on data column value?
Sumit Sharma [via OSGeo.org] wrote:
> I use CLASSITEM for only one value, I think you can not use it for
> multiple values.
> However for your problem you can easily solve it by using expression
> in class and color value in style
> As for your example...
>  CLASS
>       NAME "PIG"
>       EXPRESSION ([ANIMAL] = 'PIG')
>       STYLE
>         ANGLE 360
>         COLOR [ANIMALCOLOR]
>         OUTLINECOLOR 0 0 0
>         SIZE 10
>         SYMBOL "YourPointSymbol"
>         WIDTH 1
>       END
>     END
> and so on you can make other classes for different "animals"
> Hope this will resolve your problem
> View message @
> http://osgeo-org.1803224.n2.nabble.com/Mapfile-multiple-CLASSITEM-s-tp5388609p5388702.html
> To unsubscribe from Mapfile multiple CLASSITEM's, click here
> <http://osgeo-org.1803224.n2.nabble.com/template/NodeServlet.jtp?tpl=unsubscribe_by_code&node=5388609&code=ZG9uYXRhcy5tYWxpbmF1c2thc0BsZ3QubHR8NTM4ODYwOXwyNzc3OTQw>.
