[mapserver-users] Re: GeoRaster via gdal on Ubuntu
Daniel Morissette dmorissette at mapgears.com
Wed Aug 11 09:26:54 EDT 2010
Where is the new GDAL lib installed? Did you update your runtime libpath
to point to the new GDAL lib location? And if so how ? (LD_LIBRARY_PATH
or ld.so.conf?)
If you used LD_LIBRARY_PATH, then you need to make sure the value is
passed to your CGIs by Apache by adding a "PassEnv LD_LIBRARY_PATH"
directive to your httpd.conf.
Also, you can use the command "ldd mapserv-custom" to determine which
copy of libgdal.so is being used.
Daniel
Sebastian E. Ovide wrote:
> I have just built MapServer... just in case..
> ./configure --with-gdal=/home/sebas/gdal/bin/gdal-config
> make
> sebas at SeansPC:~/mapserver/mapserver-5.6.5$ ./mapserv -v
> MapServer version 5.6.5 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=SVG SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV INPUT=EPPL7
> INPUT=GDAL INPUT=SHAPEFILE
> cd /usr/lib/cgi-bin/
> ln -s /home/sebas/mapserver/mapserver-5.6.5/mapserv mapserv-custom
> and changed index.html to point to mapserv-custom
> the problem is still there...
> any other ideas ?
> On Wed, Aug 11, 2010 at 11:33 AM, Sebastian E. Ovide
> <sebastian.ovide at gmail.com <mailto:sebastian.ovide at gmail.com>> wrote:
>     Hi All,
>     I've installed MapServer via ubuntugis repo and build gdal by hand
>     in order to support oracle
>     sebas at SeansPC:~/mapserver$ /usr/lib/cgi-bin/mapserv -v
>     OUTPUT=WBMP OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG
>     SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=FRIBIDI
>     SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
>     SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER
>     SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS SUPPORTS=RGBA_PNG
>     INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
>     sebas at SeansPC:~/mapserver$ gdalinfo --version
>     GDAL 1.7.2, released 2010/04/23
>     sebas at SeansPC:~/mapserver$ gdalinfo --formats | grep GeoRaster
>       GeoRaster (rw+): Oracle Spatial GeoRaster
>     sebas at SeansPC:~/mapserver$ which gdalinfo
>     /home/sebas/gdal/bin/gdalinfo
>     now I'm trying to use MapServer with gdal to read GeoRasters but I'm
>     getting this error:
>     georaster:geoserver,geoserver,MFPRODUK_11G,LSLIDE_V5_RASTER,georaster,id=1
>     and from command line:
>     Driver: GeoRaster/Oracle Spatial GeoRaster
>     Files: none associated
>     Size is 24402, 49770
>     Coordinate System is:
>     PROJCS["British National Grid",
>         GEOGCS["Ordnance Survey Great Brit",
>             DATUM["Ordnance Survey Great Brit",
>                 SPHEROID["Airy
>     1830",6377563.396,299.3249646],375,-111,431,0,0,0,1],
>             PRIMEM["Greenwich",0.000000],
>             UNIT["Decimal Degree",0.01745329251994330]],
>         PROJECTION["Transverse_Mercator"],
>         PARAMETER["Scale_Factor",0.9996012717],
>         PARAMETER["Central_Meridian",-2.000000],
>         PARAMETER["Latitude_Of_Origin",49.000000],
>         PARAMETER["False_Easting",400000.000000],
>         PARAMETER["False_Northing",-100000.000000],
>         UNIT["Meter",1.000000000000]]
>     Origin = (49950.000000000000000,1250050.000000000000000)
>     Pixel Size = (25.000000000000000,-25.000000000000000)
>     Image Structure Metadata:
>       INTERLEAVE=PIXEL
>       COMPRESSION=DEFLATE
>     Corner Coordinates:
>     Upper Left  (   49950.000, 1250050.000) (  8d28'31.89"W, 60d58'39.59"N)
>     Lower Left  (   49950.000,    5800.000) (  6d52'14.32"W, 49d50'57.59"N)
>     Upper Right (  660000.000, 1250050.000) (  2d49'4.15"E, 61d 2'50.13"N)
>     Lower Right (  660000.000,    5800.000) (  1d37'14.80"E, 49d53'42.66"N)
>     Center      (  354975.000,  627925.000) (  2d42'48.98"W, 55d32'34.62"N)
>     Band 1 Block=256x256 Type=Byte, ColorInterp=Gray
>       NoData Value=255
>       Overviews: 12201x24885, 6100x12442, 3050x6221, 1525x3110,
>     762x1555, 381x777, 190x388, 95x194
>     So I suspects that MapServer is using the wrong gdal...
>     is gdal binding hardcoded into MapServer ? or MapServer would use
>     gdal from the path ?
>     Thanks
>     Sebastian E. Ovide
> Sebastian E. Ovide
> mapserver-users at lists.osgeo.org
Daniel Morissette
http://www.mapgears.com/
