[mapserver-users] Openlayers + Bing Maps with Mapserver WMS
projection error...
Luigi Castro Cardeles
luigi.cardeles at gmail.com
Wed Aug 11 23:25:17 EDT 2010
try http://trac.openlayers.org/wiki/SphericalMercator
This can be added to /usr/share/epsg/proj, and thus
MapServer<http://trac.openlayers.org/wiki/MapServer>,
GDAL, etc. by adding the following line to the file:
<900913> +proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0
+x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +no_defs
[]'s
2010/8/11 Paul james <pauljame at gmail.com>
> Thanks for the help...
> I tried use spherical marcator like that:
> var bing= new OpenLayers.Layer.VirtualEarth("Shaded", {
> type: VEMapStyle.Shaded, numZoomLevels: 10,sphericalMercator: true
> And use that projection in mapfile and openlayers:
> PROJECTION
> "+init=epsg:3857"
> Openlayers
> map = new OpenLayers.Map('Test', {
> resolutions: [0.09524345064126273, 0.0730199788249681,
> 0.047621725320631365, 0.031747816880420915, 0.015873908440210457,
> 0.009524345064126272, 0.0031747816880420914, 0.0015873908440210457,
> 0.0007936954220105228, 0.00031747816880420915],
> projection: "EPSG:4326",
> maxExtent: new OpenLayers.Bounds(-102.2607421875, -46.142578125,
> 4.7021484375, 13.623046875)
> But using that, my wms layers "disappear"... To other projection maybe?
> Any idea?
> Thanks
> On Wed, Aug 11, 2010 at 12:35 PM, Edward Mac Gillavry <
> emacgillavry at hotmail.com> wrote:
>> Bing maps is also using EPSG: 900913, EPSG:3785 or EPSG:3857 whichever is
>> the latest... That should do the trick.
>> HTH
>> Edward
>> Date: Wed, 11 Aug 2010 11:12:47 -0300
>> From: pauljame at gmail.com
>> To: mapserver-users at lists.osgeo.org
>> Subject: [mapserver-users] Openlayers + Bing Maps with Mapserver WMS
>> projection error...
>> Hey guys...
>> When using Bing maps as base layer, I have huge difference between my data
>> ... Both are using WGS84 projection...
>> The image is attached...
>> Any idea?
>> Thanks
>> My WMS map:
>> MAP
>> PROJECTION
>> "+init=epsg:4326"
>> END
>> WEB
>> IMAGEPATH 'D:\Temp'
>> IMAGEURL '/tmp/'
>> QUERYFORMAT 'text/html'
>> METADATA
>> "wms_title" "WMS Server" ##required
>> "wms_onlineresource" "http://localhost/cgi-bin/mapserv.exe?"
>> ##required
>> "wms_srs" "EPSG:4269 EPSG:4326 EPSG:42304 EPSG:42101
>> EPSG:900913" ##recommended
>> "wms_feature_info_mime_type" "text/html"
>> "labelcache_map_edge_buffer"
>> "-10"
>> END
>> END
>> LAYER
>> NAME STATE
>> METADATA
>> "wms_title" "STATE" ##required
>> END
>> TYPE polygon
>> STATUS ON
>> INCLUDE "Connection.map"
>> DATA "..."
>> PROCESSING "CLOSE_CONNECTION=DEFER"
>> PROCESSING "LABEL_NO_CLIP=ON"
>> PROJECTION
>> "init=epsg:4326"
>> END
>> My Openlayers config:
>> displayProjection: new OpenLayers.Projection("EPSG:4326"),
>> tileSize: new OpenLayers.Size(400, 400),
>> _______________________________________________ mapserver-users mailing
>> list mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100812/a5e750aa/attachment.html
