[mapserver-users] need suggestions to implement simple dynamic zoom, pan & select capabilities?!!
Wim Vanbelle wimvanbelle at gmail.com
Fri Aug 13 02:19:15 EDT 2010
Usually, when displaying mapserver data on basemap layers such as
openlayers, or directly on google  / bing maps, you would use their tiling
system.
There's examples here of how you would do this in openlayers :
http://docs.openlayers.org/library/spherical_mercator.html
On 13 August 2010 07:16, mani2604 <mani2604 at gmail.com> wrote:
> hi there...
>          I've been using phpmapscript for on-the fly query & displaying the
> resultant images... Now that I've got this problem that I tried using both
> mscross & openlayers to display the image but somehow I cud not work it
> out.. I mean in both the above frameworks we need to specify the output
> image in the sort of URL tag-line style(wms)  as below...
> eg:-
> http://localhost/index.php?mode=map&map=/ms4w/apache/htdocs/india_roads1.map&mapext=60+7+102+38.5&mapsize=640+480&layers=SARDINIA%20india_ds%20IND_water_areas_dcw%20&undefined
>                       Or may be I am wrong..Can we just specify the
> location of the resultant image and add all those dynamic zoom,pan
> functionality in 'Open Layers'
>                       i am sory If I am not clear enough but i need some
> suggestions for some simple script like mscross or soo where I need to add
> all those dynamic functions to my output image... that's it
> Thanks...!!@
> http://osgeo-org.1803224.n2.nabble.com/need-suggestions-to-implement-simple-dynamic-zoom-pan-select-capabilities-tp5418885p5418885.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100813/fcdcb230/attachment.html
