[mapserver-users] logging GDAL queries
Bart van den Eijnden
bartvde at osgis.nl
Fri Aug 13 04:36:19 EDT 2010
Add CONFIG "CPL_DEBUG" "ON" to your MAP object in the MAP file. Probably wise to add DEBUG 5 to your MAP and LAYER as well.
Also add something like:
CONFIG "MS_ERRORFILE" "stderr" and then check your Apache error log.
Best regards,
Bart
Looking for flexible support on OpenLayers or GeoExt? Please check out http://www.osgis.nl/support.html
OSGIS
bartvde at osgis.nl
On Aug 13, 2010, at 10:33 AM, Sebastian E. Ovide wrote:
> Hi All
> I am using MapServer + GDAL to render GeoRasters and I am having very poor performance reading GeoRasters at a high zoom level... over 13... it would take even 20 seconds per tile...
> Is it possible to log the GDAL queries that MapServer is doing? (and the SQL queries that GDAL is doing ?)
> thanks
> Sebastian E. Ovide
> mapserver-users at lists.osgeo.org
