[mapserver-users] how to disappear Warning: session_start() in the page?
Carlos Ruiz boolean10001 at yahoo.com
Wed Aug 18 16:51:43 EDT 2010
Elisabeth,
It's quite as simple as the session handling. You can split your code into many
files or keep it in one single file,
the only thing you have to know is that PHP's session_start() function call must
be the first thing wrote, no
HTML or PHP code before that.
Cheers from México
IC Carlos Ruiz
To: mapserver-users at lists.osgeo.org
Sent: Wed, August 18, 2010 2:48:58 PM
Subject: Re: [mapserver-users] how to disappear Warning: session_start() in the
page?
Hello Mr. Sumariva, i already did wht u said, but there's new error: error:
Call to undefined function:  on_get_contens() in
I:\ms4w\apps\appweb\htdocs\index_cobacham.phtml on line 2
here i put the cobachanphtml.phtml:
<?php
$html=on_get_contens();
ob_end_clean();
include("./chameleon.php");
    $szTemplate="./template_werror.html";
    $szMapFile="../map/kelur_cobacham.map";
    class SampleApp extends Chameleon //SampleApp merupakan turunan dari
Chameleon
        function SampleApp() //Nama fungsi
            parent::Chameleon(); //Menjalankan konstruktor class Chameleon
            $this->moMapSession=new MapSession_RW; //Mbwt instance obj map
session
             $this->moMapSession->setTempDir
        (getSessionSavePath()); //Mendefinisikan dir temporer yg akn digunk olh
        obj map
session
    $oApp= new SampleApp(); //Membut instance obj SampleApp
    $oApp->registerSkin('skins/sample'); //mendefinisikan skin utk obj SampleApp
    $oApp->CWCInitialize($szTemplate, $szMapFile); //MEnginisialisasi obj Lat01
dg                                                      file template dan file
.map
    $oApp->CWCExecute(); //Menjalankan app dg memangil fs CWCExecute
So, what should i do?
 Thanks a lot for the attention, sorry reply not direct.
To: elisabeth theresia <dbee_kawai at yahoo.com>
Sent: Tue, August 17, 2010 12:34:39 AM
page?
Well, you can turn the things by other way.
Put at top of HTML file in the ob_start() function to tell PHP to buffer all
output.
Change your your index_cobachan by adding
$html = ob_get_contens();
ob_end_clean();
Now all the content that would be sent to browser is available at $html string
variable.
After the includes in your index_cobachan print the contents of $html var.
Now do your application logic.
THen append the rest of HTML file.
Another option is to turn your HTML file into a template and add a special mark
to signal template engine to replace some content but this would be another
aproach.
2010/8/13 elisabeth theresia <dbee_kawai at yahoo.com>
Thanks Mr.Sumariva for the advice but, session_start() in the page already embed
in Chameleon framework at its folder in \htdocs\common\session
>the coding at line 509 (that shown error in the page):
>//start the session
>    session_start();
>    register_shutdown_function( "session_write_close" );
>    // set IP if a new session
>    if ( $bNewSession ) $_SESSION["gszRemoteAdd"] = $_SERVER["REMOTE_ADDR"];
> * Check IP to see if it is the same
>    // check if the IP has been set and validate
>    if ( isset( $_SESSION["gszRemoteAdd"] ) &&
>                                   strlen(trim($_SESSION["gszRemoteAdd"])) > 0
>        // check if IP matches current client
>        if ( trim( $_SESSION["gszRemoteAdd"] ) !=
>                                               trim( $_SERVER["REMOTE_ADDR"] )
>            // possible security breach void session
>            /* if the session address is the loopback interface then it is
>             * likely that the application was configured to use an external
>             * address but someone is trying to test locally using localhost
>            if ($_SESSION['gszRemoteAdd'] != '127.0.0.1')
>                $bSessionOK = false;
>    else
>    // return success or failure and set global so we
>    // know session has been inited.
>    if ($bSessionOK)
>        $GLOBALS['session_started'] = true;
>    return $bSessionOK;
>// end intializeSession() function
>function getSessionSavePath()
>    $szReturn  = ini_get("session.save_path")."/sess_".session_id()."/";
>    $szReturn = str_replace( "\\", "/", $szReturn );
>    return $szReturn;
>Really need advice again Mr.
>Thanks
>Sent: Sat, August 14, 2010 8:57:29  AM
>page?
>You should break your file in 2 files.
>Put the session_start function at first and add it to the top of your .phtml
>file.
>The second file will contain all remaining code.
>When using session in pages they have to be sent before any other thing.
>This is a requirement in HTTP protocol.
>Hi all, i got message (for preview- i attached the page in
>attachment-sessionerror2.jpg) :
>>Warning:  session_start() [function.session-start]:  Cannot send session cache
>>limiter - headers already sent (output  started at
>>I:\ms4w\apps\appweb\htdocs\index_spatialphtml.phtml:6) in
>>I:\ms4w\apps\appweb\htdocs\common\session\session.php509 on line
>>i have mapfile and template that already could show in the initialize page named
>>Then my html + php = index_spatialphtml.phtml
>>i put <?php include ("index_cobacham.phtml")?> above the syntax html.
>>Thanks :)
>>here the index_spatialphtml.phtml
>>http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
>><head>
>><meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
>><title>index</title>
>><style type="text/css">
>>body {
>>    font: 100% Verdana, Arial, Helvetica,  sans-serif;
>>     background: #666666;
>>    margin: 0; /* it's good practice to zero the margin and padding of the body
>>element to account for differing browser defaults */
>>    padding: 0;
>>    text-align: center; /* this centers the container in IE 5* browsers. The
>>text is then set to the left aligned default in the #container selector */
>>    color: #000000;
>>    background-image: url(./images/Background.gif);
>>.oneColElsCtr #container {
>>    width: 46em;
>>    background: #FFFFFF;
>>    margin: 0 auto; /* the auto margins (in conjunction with a width) center the
>>page */
>>    border: 1px solid #000000;
>>    text-align: left; /* this overrides the text-align: center on the body
>>element. */
>>.oneColElsCtr #mainContent {
>>    padding: 0 20px; /* remember that padding is the  space inside the div box
>>and margin is the space outside the div box */
>>.style1 {color: #FFFFFF}
>>a:link {
>>    color: #96711D;
>>    text-decoration: none;
>>a:visited {
>>    color: #A99559;
>>a:hover {
>>    color: #990000;
>>    text-decoration: underline;
>>a:active {
>>    color: #000000;
>>.style2 {color: #000000}
>></style></head>
>><body class="oneColElsCtr">
>><div id="container">
>>  <div id="mainContent">
>>    <table width="713" border="1">
>>      <tr background="./images/Background.gif">
>>        <th width="709" scope="col" align="center"><p class="style1">PETA
>>SPASIAL PENYEBARAN PENYAKIT DBD</p>
>>        <p class="style1"> KOTA SURAKARTA</p></th>
>>      </tr>
>>    </table>
>>    <table width="717" border="1" cellpadding="0" cellspacing="0">
>>      <tr>
>>        <th width="138" scope="col"><div align="center"><a
>>href="index.html">Beranda</a></div></th>
>>        <th width="171" scope="col"><div align="center"><a href="peta.html">Peta
>>Surakarta</a></div></th>
>>        <th width="127" scope="col"><div align="center"><a
>>href="berita.html">Berita</a></div></th>
>>        <th width="147"  scope="col"><div align="center"><a
>>href="tentang.html">Buku Tamu</a></div></th>
>>        <th width="122" scope="col"><div align="center"><a href="tentang.html"
>>target="_blank" class="style2">Tentang</a></div></th>
>>      </tr>
>>    </table>
>><?php
>>   include ("./index_cobacham.phtml"); ?>
>></body>
>></html>
>>_______________________________________________
>>mapserver-users mailing list
>>http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100818/28d60886/attachment-0001.html
