[mapserver-users] Mapserver tile generation - google maps
Wim Vanbelle
wimvanbelle at gmail.com
Fri Aug 20 08:31:32 EDT 2010
I was using AGG for the rendering. I suppose I need to look for updates for
that? ;).
On 20 August 2010 14:08, Wim Vanbelle <wimvanbelle at gmail.com> wrote:
> I'll try updating GD. Thanks.
> TileCache is probably not an option, as the color of the data changes every
> minute. That would mean that tilecache has to reset its data every minute.
> Not sure if that is possible, or rather, wanted behaviour.
> OpenLayers would have been a good option, but for some odd reason the
> client wants the 'real google maps' interface :).
> In any case, thanks for your help.
> On 20 August 2010 13:48, <christopher.schmidt at nokia.com> wrote:
>> On Aug 20, 2010, at 7:26 AM, ext Wim Vanbelle wrote:
>> > Hi all,
>> > I noticed a similar post regarding symbol issues, but there was no
>> solution.
>> > My Google maps tiles are currently clipped at the tile itself. This
>> results in rather unwanted behaviour:
>> > http://fileshare.myroute.be/exchange/Capture.PNG
>> I think the answer to this is "Use a more recent GD." If that's not
>> an option, then you'll need to expand the frame of the selected image
>> to be slightly larger than the actual image itself; this is possible
>> with TileCache (metaBuffer), OpenLayers (gutter), etc.
>> -- Chris
>> > I'm not 100% sure that this is mapservers' 'issue' , or google maps
>> issue.
>> > If anyone would have further tips to spice up the graphics even more,
>> I'd be more than glad to hear them :).
>> > Thanks.
>> > Wim
>> > <ATT00001..txt>
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100820/5d80da12/attachment.html
