[mapserver-users] shp/dbf file's name
Clément MONIER
Clement.MONIER at v-trafic.com
Fri Aug 20 10:06:29 EDT 2010
> How would MapServer know which row in your external dbf file matches which row (aka feature) in your ShapeFile?
> What if the external dbf file doesn't have the same number of rows as the number of features in your ShapeFile?
not really a problem as I'm able to generate dbf files with records in exactly same number and order as inside shp.
> The dbf format is pretty primitive. Your best bet is to actually add to your ShapeFile the data that is now in your external file. > It will also likely be faster.
That's precisely what I can't do any more,
since I'd like to join various kinds of time-related attributes on very static geometries.
-----Message d'origine-----
De : P Kishor [mailto:punk.kish at gmail.com]
Envoyé : vendredi 20 août 2010 15:42
À : Clément MONIER
Cc : mapserver-users at lists.osgeo.org
Objet : Re: [mapserver-users] shp/dbf file's name
On Fri, Aug 20, 2010 at 8:22 AM, Clément MONIER
<Clement.MONIER at v-trafic.com> wrote:
> Hi,
> I would like to know if it's possible to draw geometries from a shp file
> according to attributes from a dbf
> but with 2 files named differently.
> For instance :
> LAYER
> NAME layer1
> DATA shapefile1.shp
> CLASS
> EXPRESSION ([col1]=1)
> STYLE
> END
> END
> END
> Where col1 is a field inside a file storing attributes (dbf/csv/txt/.) but
> not named shapefile1.dbf
which row (aka feature) in your ShapeFile? What if the external dbf
your ShapeFile?
to your ShapeFile the data that is now in your external file. It will
> I already tried to use the JOIN option but I think it's inappropriate for my
> purpose
> since "You cannot use joins to affect the look of a map"
> (http://mapserver.org/mapfile/join.html)
> Thanks for your help !
> Clément
Puneet Kishor http://www.punkish.org
Carbon Model http://carbonmodel.org
Charter Member, Open Source Geospatial Foundation http://www.osgeo.org
Science Commons Fellow, http://sciencecommons.org/about/whoweare/kishor
Nelson Institute, UW-Madison http://www.nelson.wisc.edu
Assertions are politics; backing up assertions with evidence is science
