[mapserver-users] maps all look squished
Josh Jordan outerspaceman81 at yahoo.com
Fri Aug 20 10:24:03 EDT 2010
The projection in the mapfile is "init=epsg:2023".  This is the same projection between /MAP/,/END/ as it is for all the projections between /LAYER/,/END/.  When the projection of a layer is not the same as the projection of the map, the layer does not print.  It seems redundant to have to write the same projection everywhere.
I request the map image with:ms_newMapObj($PM_MAP_FILE);
--- On Fri, 8/20/10, Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi> wrote:
From: Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi>
Subject: Re: [mapserver-users] maps all look squished
To: "Josh Jordan" <outerspaceman81 at yahoo.com>,
 mapserver-users at lists.osgeo.org
Date: Friday, August 20, 2010, 8:04 AM
What is the projection of your layer data, what is the projection for the output, and how do you request the image from Mapserver?
-Jukka Rahkonen-
-----Alkuperäinen viesti-----
Lähettäjä: mapserver-users-bounces at lists.osgeo.org puolesta: Josh Jordan
Lähetetty: pe 20.8.2010 6:16
Vastaanottaja: mapserver-users at lists.osgeo.org
Aihe: [mapserver-users] maps all look squished
No matter what projection I use, my maps always look stretched too wide, or squished.  What could be the problem?  What can I do?  Attached is a picture of the problem, the
 top michigan is correct, the bottom one is generated in mapserver.
Can anyone from Michigan suggest a projection where the state looks the most correct?
Thanks.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100820/5839c555/attachment.html
