[mapserver-users] Tile mode & multiple layers
Clément MONIER Clement.MONIER at v-trafic.com
Wed Aug 25 08:37:39 EDT 2010
Thanks a lot !
I have another bothering issue :
PNG outputs of my MS CGI requests now don’t look nicely rendered any more (i.e no smoothly antialiased AGG display)
http://localhost/cgi-bin/mapserv.exe?mode=tile&tilemode=gmap&tile=X+Y+S&map=mymapfile.map&LAYERS=layer1 layer2<http://localhost/cgi-bin/mapserv.exe?mode=tile&tilemode=gmap&tile=X+Y+S&map=mymapfile.map&LAYERS=layer1%20layer2>
as it was with similar WMS requests targeting the same mapfile though
Where should I specify the desired output format ?
Thank you for your help
De : mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] De la part de Wim Vanbelle
Envoyé : mercredi 25 août 2010 13:50
À : mapserver-users at lists.osgeo.org
Objet : Re: [mapserver-users] Tile mode & multiple layers
Hi Clément,
Your request is wrong ;).
Try using a space instead. Take a look here :
Good luck.
On 25 August 2010 13:47, Clément MONIER <Clement.MONIER at v-trafic.com<mailto:Clement.MONIER at v-trafic.com>> wrote:
I’m facing a (probable widely encountered) problem using MapServer with tile-mode option.
It seems like multiple layers aren’t allowed ??
http://localhost/cgi-bin/mapserv.exe?mode=tile&tilemode=gmap&tile=X+Y+S&map=mymapfile.map&LAYERS=layer1 => ok
http://localhost/cgi-bin/mapserv.exe?mode=tile&tilemode=gmap&tile=X+Y+S&map=mymapfile.map&LAYERS=layer2 => ok
http://localhost/cgi-bin/mapserv.exe?mode=tile&tilemode=gmap&tile=X+Y+S&map=mymapfile.map&LAYERS=layer1,layer2 => ko !
Why ?
Thanks & Regards
mapserver-users mailing list
mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100825/6a55d66b/attachment.html
