[mapserver-users] external graphic symbol don't follow the
GetStyles method
Martin Ouellet
geomartino at gmail.com
Wed Dec 1 14:50:34 EST 2010
You're absolutely right Assefa, adding the parameter WMS_SLD_SYMBOL_URL
solve the problem. You're also right in saying that the information is
somehow hidden BUT it is there so my mistake, I'll try to read more
carefully next time
MartinO
2010/12/1 Yewondwossen Assefa <yassefa at dmsolutions.ca>
> Hi Martin,
> I think you need to define WMS_SLD_SYMBOL_URL to be able to generate an
> External graphic. This is documented (almost hidden :) in
> http://mapserver.org/ogc/sld.html#client-side-support
> best regards,
> On 30/11/2010 5:01 PM, Martin Ouellet wrote:
> Hi,
> When I used a external graphic element in a SLD like this:
> <Name>test</Name>
> <ogc:Filter><ogc:PropertyIsEqualTo><ogc:PropertyName>indicatif</ogc:PropertyName><ogc:Literal>1030050000</ogc:Literal></ogc:PropertyIsEqualTo></ogc:Filter>
> <MaxScaleDenominator>40000.000000</MaxScaleDenominator>
> <Graphic>
> <ExternalGraphic>
> <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink"
> xlink:type="simple" xlink:href="
> http://www2.dmsolutions.ca/msapps/world_testdata/map/etc/target-1.gif"/>
> <Format>GIF</Format>
> </ExternalGraphic>
> Then I used the temporary mapfile generated by the call to define the
> same symbology but in my mapfile.
> SYMBOL
> NAME "
> TYPE PIXMAP
> IMAGE "/srv/mapfile/ms_tmp/4cf56a54_49f8_1.gif"
> GAP -11
> TRANSPARENT 0
> END
> CLASS
> NAME "test"
> EXPRESSION ([indicatif] = 1030050000)
> MAXSCALEDENOM 40000
> STYLE
> ANGLE 360
> COLOR 0 0 0
> SIZE 5.5
> SYMBOL "
> WIDTH 1
> END
> END
> Question: Finally, I would like to expose this symbology through the
> GetStyles() method but it seem to be completely ignored?
> <Name>test</Name>
> <PointSymbolizer>
> </PointSymbolizer>
> Is it normal? Thank you in advance!
> MartinO
> mapserver-users mailing listmapserver-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/mapserver-users
> Assefa Yewondwossen
> Software Analyst
> Email: yassefa at dmsolutions.ca http://www.dmsolutions.ca/
> Phone: (613) 565-5056 (ext 14)
> Fax: (613) 565-0925
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20101201/a112450b/attachment.html
