[mapserver-users] OGR Join To MS-Access Without Using ODBC
Brent Fraser bfraser at geoanalytic.com
Fri Dec 3 09:56:16 EST 2010
James,
   Is it the ODBC system you don't want to use, or just the need to
create an ODBC DataSource?  To avoid creating a DataSource, I tried
using ogrinfo (v1.7.1) on the command line:
ogrinfo ODBC:"Driver={Microsoft Access Driver
(*.mdb)};Dbq=t_505033.mdb",basic basic
and that worked.  But the need for quoting caused mapserver v5.6.3 to
crash when I tried single quotes around the ODBC portion:
DATA "SELECT * FROM t_505033 LEFT JOIN ODBC:'Driver={Microsoft Access
Driver (*.mdb)};Dbq=G\GeoData\Parcels\Alberta\t_505033.mdb'.basic ON
t_505033.PID=basic.PID"
or
     DATA "SELECT * FROM t_505033 LEFT JOIN 'ODBC:Driver={Microsoft
Access Driver (*.mdb)};Dbq=G\GeoData\Parcels\Alberta\t_505033.mdb'.basic
ON t_505033.PID=basic.PID"
I wonder if there is a way to escape the double quotes in the DATA object?
Best Regards,
Brent Fraser
On 12/2/2010 10:30 PM, James Card wrote:
> I'm trying to determine what syntax to use to create an OGR join to an
> MS Access database *without* using ODBC (on a Windows server). Is that
> possible?
> Current syntax is: DATA "SELECT * FROM LHFO_Routes shp LEFT JOIN
> 'ODBC:Routes_MDB,vRoutesTheme'.vRoutesTheme mdb ON
> shp.ROAD_NO_=mdb.RouteNumber"
