[mapserver-users] OGR Join To MS-Access Without Using ODBC
James Card
James.Card at calcad.com
Fri Dec 3 11:19:36 EST 2010
On Fri, 03 Dec 2010 06:56:16 -0800, Brent Fraser <bfraser at geoanalytic.com>
wrote:
> Is it the ODBC system you don't want to use, or just the need to
> create an ODBC DataSource? To avoid creating a DataSource, I tried
> using ogrinfo (v1.7.1) on the command line:
We're hoping to eliminate ODBC entirely. If OGR has an alternate method to
connect to Access that is faster, that is what we're looking for.
Thanks for your tip on using the connection string for DSN-less
connections; that may be useful too.
James Card
California CAD Solutions, Inc.
209-578-5580 - Voice
209-521-6493 - FAX
