[mapserver-users] Using OGR with a TILEINDEX layer
Brent Fraser
bfraser at geoanalytic.com
Fri Dec 3 14:52:43 EST 2010
Frank,
That did the trick! For those interested, I used:
LAYER # LINE
NAME 'LINE'
STATUS on
TYPE LINE
TILEINDEX "G:\GeoData\1_250k\Alberta\AltaLIS\250k_west.shp" #
"index_west"
CONNECTIONTYPE OGR
INCLUDE "AltaLIS_250k_render_inc.map"
END
Thanks!
Best Regards,
Brent Fraser
On 12/3/2010 11:43 AM, Frank Warmerdam wrote:
> Brent Fraser wrote:
>> I used ogrtindex to create a tileindex shapefile with absolute paths
>> but get an error in mapserver v5.6.1 when attempting to use it:
>> msDrawMap(): Image handling error. Failed to draw layer named
>> 'LINE'.
>> msOGRFileOpen(): OGR error. Open failed for OGR connection in layer
>> `LINE'. File not found or unsupported format
>> LAYER
>> NAME "index_west"
>> TYPE TILEINDEX
>> DATA "G:\GeoData\1_250k\Alberta\AltaLIS\250k_west.shp"
>> END
>> LAYER # LINE
>> NAME 'LINE'
>> STATUS on
>> TYPE LINE
>> TILEINDEX "index_west"
>> CONNECTIONTYPE OGR
>> # CONNECTION 'G:\GeoData\1_250k\Alberta\AltaLIS\82opos.dgn' #
>> entities'
>> END
>> Does OGR work when referencing a TILEINDEX?
> Brent,
> I don't have an authoritative answer, but a brief skim of mapogr.cpp
> seems
> to suggest that it only supports tileindexes in OGR supported formats and
> not in a separate layer. So, the answer seems to be no, though you
> should
> be able to just specify the 250k_west.shp file directly as your tileindex
> in the main OGR layer.
> It would be desirable to rework mapogr.cpp to support the current more
> general concept of tileindexes but it might be a non-trivial amount of
> work
> and significant care would be required to avoid backward compatibility
> problems.
> Best regards,
