[mapserver-users] WMS image doesn't shows at major scales
Carlos Ruiz boolean10001 at yahoo.com
Mon Dec 6 14:18:09 EST 2010
Hi to all,
I have a problem here with an WMS layer, and have no clue about what could be
happening. I have an ECW file
with the following info:
Driver: ECW/ERMapper Compressed Wavelets
Files: mosaico_spot_2009.ecw
Size is 192034, 184370
Coordinate System is `'
Origin = (425473.750000000000000,2527371.250000000000000)
Pixel Size = (2.500000000000000,-2.500000000000000)
Corner Coordinates:
Upper Left  (  425473.750, 2527371.250)
Lower Left  (  425473.750, 2066446.250)
Upper Right (  905558.750, 2527371.250)
Lower Right (  905558.750, 2066446.250)
Center      (  665516.250, 2296908.750)
Band 1 Block=192034x1 Type=Byte, ColorInterp=Red
  Overviews: arbitrary
  Metadata:
    LAYER_TYPE=athematic
Band 2 Block=192034x1 Type=Byte, ColorInterp=Green
  Metadata:
Band 3 Block=192034x1 Type=Byte, ColorInterp=Blue
  Metadata:
It is provided as a WMS and here is the MAP file contents:
MAP
        NAME 'spot'
        SIZE 800 600
        UNITS meters
        DEBUG 5
        CONFIG "MS_ERRORFILE" "/var/www/html/spot.log"
        EXTENT 425473 2066446 905559 2527371
        PROJECTION
                'proj=utm'
                'ellps=WGS84'
                'datum=WGS84'
                'zone=13'
                'north'
                'nodefs'
        END
        OUTPUTFORMAT
                NAME jpeg
                DRIVER "GD/JPEG"
                MIMETYPE "image/jpeg"
                IMAGEMODE RGB
                EXTENSION "jpg"
        END
        METADATA
                        'wms_title'                             'SPOT'
                        'wms_onlineresource'
'http://sitel.jalisco.gob.mx/cgi-bin/spot'
                        'wms_srs'                               'EPSG:32613'
                        'wms_fees'                              'none'
                        'wms_contactperson'                     'IC Carlos Ruiz'
                        'wms_contactelectronicmailaddress'
'cruizch at gmail.com'
        END
        LAYER
            NAME 'spot'
            TYPE RASTER
            DATA '/var/www/html/raster/spot.ecw'
            STATUS DEFAULT
            PROJECTION
                'proj=utm'
                'ellps=WGS84'
                'datum=WGS84'
                'zone=13'
                'north'
                'no_defs'
            END
            METADATA
                'wms_title' 'Imagen SPOT'
            END
        END
END
Everything works fine above the 1:152,000 scale, but when you try to reach major
scales, it shows nothing. The
map has no MINSCALEDENOM nor MAXSCALEDENOM.
Taking a look at the log file, nothing's wrong. If I set the "MS_NONSQUARE"
config key throws:
msDrawMap(): kicking into non-squarepixel preserving mode.
but nothing yet shows beyond 1:152,000.
Does anyone have a clue about what's wrong ? I'm using Mapserver 5.6.5
Thanks in advance
IC Carlos Ruiz
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20101206/41fb636c/attachment-0001.html
