[mapserver-users] displaying 3-band images
David Hildebrand
David.Hildebrand at afsc.ca
Thu Dec 9 17:13:55 EST 2010
Jukka:
For now I am making a simple Mapserver CGI call (http://localhost/cgi-bin/mapserv.exe?map=MSTEST&layer=awifs&mode=map). This URL works for other raster layers but I have only had single-band images so far. In all cases the final map is in a projection different from the layer projection. Incidentally, when I point to a data source which I know does not exist I get the same behavior (no image and no error) even when I use CONFIG "ON_MISSING_DATA" "FAIL" in my map file.
Thanks for your help.
David V. Hildebrand
Agriculture Financial Services Corporation
(403) 782-8239
www.afsc.ca <http://www.afsc.ca>
This communication is intended for the use of the recipient to which it is addressed, and may contain confidential, personal and/or privileged information. Please contact Agriculture Financial Services Corporation immediately if you are not the intended recipient of this communication, and do not copy, distribute, or take action relying on it. Any communication received in error, or subsequent reply, should be deleted or destroyed. Please consider the environment before printing this email.
-----Original Message-----
From: Rahkonen Jukka [mailto:Jukka.Rahkonen at mmmtike.fi]
Sent: Thursday, December 09, 2010 2:21 PM
To: David Hildebrand
Subject: Re: [mapserver-users] displaying 3-band images
I will have a closer look tomorrow. What did you use for showing the image? Mapserver CGI call or WMS client or what? Could you send the request as well?
Regards,
-Jukka-
-----Alkuperäinen viesti-----
Lähettäjä: David Hildebrand [mailto:David.Hildebrand at afsc.ca]
Lähetetty: to 9.12.2010 22:32
Vastaanottaja: Rahkonen Jukka
Aihe: RE: [mapserver-users] displaying 3-band images
Jukka:
I posted this to the mailing list but I don't think it got there because the body was too long so I'm sending it to you directly.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20101209/59d6b579/attachment.html
