[mapserver-users] PNG Optimization
thomas bonfort
thomas.bonfort at gmail.com
Fri Dec 10 09:09:06 EST 2010
Cedric,
Mapserver currently doesn't support png options, although this
souldn't be to difficult to add as a FORMATOPTION (at least for the
non GD renderers).
You should note that the quality of the compression you apply to pngs
has a non trivial effect on the overall rendering time, so we can't
just add maximum compression by default.
ps: you can see the effect of png compression schemes (on throughput
and image size) on this small benchmark I ran for mod-geacache. the
use case is the on the fly merging of two 256x256 png tiles:
http://mod-geocache.googlecode.com/svn-history/r69/trunk/static/benchmark.png
regards,
thomas
2010/12/10 Cédric MOULLET <cedric.moullet at gmail.com>:
> Hi,
> We are using MapServer to generate tiles and the following ouptut format is
> used:
> OUTPUTFORMAT
> NAME "pnga"
> MIMETYPE "image/pnga"
> DRIVER "AGG/PNG"
> EXTENSION "png"
> IMAGEMODE "RGBA"
> TRANSPARENT TRUE
> FORMATOPTION "INTERLACE=OFF"
> END
> We observe that the size of the tiles can be reduced by a at least factor 2
> if we use a tool like optipng.
> Is it possible to configure MapServer in order to optimize the file output
> (and for example use optipng) ? Or do you see another way to optimize the
> image (I'd like to do that on the MapServer side in order to avoid a
> postprocessing) ?
> Thanks in advance for any hints.
> Cédric
> Welcome to my world: http://www.cedricmoullet.com/
> My Linked In profile: http://www.linkedin.com/in/cedricmoullet
> Twitter: http://twitter.com/cedricmoullet
> Home sweet home:
> http://map.geo.admin.ch/?crosshair=bowl&zoom=11&X=185241.24219&Y=561288.90625&bgOpacity=0&selectedNode=node_ch.swisstopo.fixpunkte-lage1
> mapserver-users at lists.osgeo.org
