[mapserver-users] MyGIS problem after upgrading 5.2.1 -> 5.6.5
Toomas Aas
toomas.aas at raad.tartu.ee
Mon Dec 13 03:50:23 EST 2010
Hello!
I have read about MyGIS being deprecated, but I'm hoping for a quick
fix for this particular problem, which wouldn't involve rewriting a
lot of queries.
We have a MyGIS layer which stopped working after upgrading Mapserver
from 5.2.1 to 5.6.5.
The data definition is:
DATA 'geometry from (select * from koht where omavalitsus_id>=-1)
feature, koht_bin geometry'
When this layer is accessed from PHP/Mapscript, the following errors
are logged by PHP:
[MapServer Error]: msQueryByPoint(): No matching record(s) found.
in source_file.php on line 35
[MapServer Error]: msMYGISLayerGetShapeRandom(): GetShape called on
MYGIS layer with invalid DB query results.
[MapServer Error]: SELECT feature.id,
feature.vertices,geometry.WKB_GEOMETRY , fe: mysql query failed
[MapServer Error]: describe (select: mysql query failed
I turned on query logging in MySQL, and the log shows that the query
being sent to MySQL is:
describe (select
which certainly *should* fail.
It seems that if I use a subquery in data definition, DESCRIBE is
being done only on first word of the subquery. If I replace the
subquery with a table name, things do not break, but this way I can't
get the result that I actually need. Can anyone suggest a workaround?
Toomas Aas
