[mapserver-users] displaying 3-band images
David Hildebrand David.Hildebrand at afsc.ca
Thu Dec 9 11:15:09 EST 2010
Jukka:
Here is the output from gdalinfo
Driver: GTiff/GeoTIFF
Files: Z:\AWiFS\initial_delivery\images\July.tif
       Z:\AWiFS\initial_delivery\images\July.aux
       Z:\AWiFS\initial_delivery\images\July.rrd
Size is 26864, 20154
Coordinate System is:
LOCAL_CS[]
Origin = (-701343.999999998950000,711367.999999999190000)
Pixel Size = (55.999999999999915,-55.999999999999950)
Metadata:
  AREA_OR_POINT=Area
  TIFFTAG_XRESOLUTION=100
  TIFFTAG_YRESOLUTION=100
Image Structure Metadata:
  INTERLEAVE=BAND
Corner Coordinates:
Upper Left  ( -701344.000,  711368.000)
Lower Left  ( -701344.000, -417256.000)
Upper Right (  803040.000,  711368.000)
Lower Right (  803040.000, -417256.000)
Center      (   50848.000,  147056.000)
Band 1 Block=26864x1 Type=Byte, ColorInterp=Red
  Min=0.000 Max=255.000
  Minimum=0.000, Maximum=255.000, Mean=48.345, StdDev=55.880
  Overviews: 6716x5039, 3358x2520, 1679x1260, 840x630, 420x315, 210x158, 105x79, 53x40
  Metadata:
    STATISTICS_MINIMUM=0
    STATISTICS_MAXIMUM=255
    STATISTICS_MEAN=48.345449373874
    STATISTICS_MEDIAN=4.8562875856817e-167
    STATISTICS_MODE=1.5919265163982e+244
    STATISTICS_STDDEV=55.880036995387
    LAYER_TYPE=athematic
Band 2 Block=26864x1 Type=Byte, ColorInterp=Green
  Minimum=0.000, Maximum=255.000, Mean=17.392, StdDev=33.316
  Metadata:
    STATISTICS_MEAN=17.392222305608
    STATISTICS_STDDEV=33.315967583066
Band 3 Block=26864x1 Type=Byte, ColorInterp=Blue
  Minimum=0.000, Maximum=255.000, Mean=24.741, StdDev=36.606
  Metadata:
    STATISTICS_MEAN=24.74071367083
    STATISTICS_STDDEV=36.605847882772
David V. Hildebrand
Agriculture Financial Services Corporation
(403) 782-8239
www.afsc.ca <http://www.afsc.ca>
This communication is intended for the use of the recipient to which it is addressed, and may contain confidential, personal and/or privileged information. Please contact Agriculture Financial Services Corporation immediately if you are not the intended recipient of this communication, and do not copy, distribute, or take action relying on it. Any communication received in error, or subsequent reply, should be deleted or destroyed. Please consider the environment before printing this email.
-----Original Message-----
From: Rahkonen Jukka [mailto:Jukka.Rahkonen at mmmtike.fi]
Sent: Wednesday, December 08, 2010 12:49 PM
To: David Hildebrand; Michael Schulz; mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] displaying 3-band images
What does gdalinfo tell about your image?
-Jukka Rahkonen-
-----Alkuperäinen viesti-----
Lähettäjä: mapserver-users-bounces at lists.osgeo.org puolesta: David Hildebrand
Lähetetty: ke 8.12.2010 21:33
Vastaanottaja: Michael Schulz; mapserver-users at lists.osgeo.org
Aihe: RE: [mapserver-users] displaying 3-band images
Michael:
I inserted the following lines in my map file.
  CONFIG "MS_ERRORFILE" "stdout"
  DEBUG 5
  CONFIG "CPL_DEBUG" "ON"
  CONFIG "PROJ_DEBUG" "ON"
  CONFIG "ON_MISSING_DATA" "FAIL"
However, the behavior is the same and I get no additional messages.  However, the following message shows up in the apache error file.
  GDAL: GDALDeregister_GTiff() called.\r
My mapserver (ms4w) has been built with GDAL support because mapserv -v gives me the following.
  MapServer version 5.3-dev OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE
  SUPPORTS=ICONV SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER
  SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
I'm wondering if there is a problem in GDAL reading the projection information because using gdalinfo on the source file gives me the following in the output.
  LOCAL_CS[]
Yet, when I add the correct projection information using gdal_translate -a_srs ... ArcView comes up with a blank image.
Any clues?
David V. Hildebrand
(403) 782-8239
www.afsc.ca <about:www.afsc.ca>  <http://www.afsc.ca <http://www.afsc.ca/> >
  _____
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Michael Schulz
Sent: Wednesday, December 08, 2010 1:20 AM
To: mapserver-users at lists.osgeo.org
are you sure your raster can be read by mapserver cgi? Maybe try adding the ON_MISSING_DATA config option at map file level to rule out this error: CONFIG "ON_MISSING_DATA" "FAIL"
Also, I think IMAGEMODE is a parameter of the outputformat object not the layer object.
Cheers, Michael
2010/12/8 David Hildebrand <David.Hildebrand at afsc.ca>
I have a TIFF image I want to display.  The image is a 3-band 8-bit image.  The server logs show no error but my display is coming out blank.  I am using ms4w with GDAL support so I'm not sure what is going wrong here.  A sample of the mapfile is shown below.  I get a parsing error if I include IMAGEMODE "RGB" in the layer definition.  Any suggestions?
LAYER
  NAME "awifs"
  PROCESSING "BANDS=3,2,1"
  PROCESSING "SCALE=AUTO"
  METADATA
    "wms_title" "awifs"
    "wms_opaque" "1"
    "ows_resolution" "56 56"
    "wms_srs" "EPSG:43001"
    "wms_extent" "-701344.000 -417256.000 803040.000 711368.000"
    "wcs_srs" "EPSG:43001"
    "wcs_extent" "-701344.000 -417256.000 803040.000 711368.000"
  END
  STATUS on
  TYPE raster
  DATA "//Plcoressatsb01/AWiFS/initial_delivery/images/July.tif"
  PROJECTION
    "init=epsg:43001"
  END
  EXTENT -701344.000 -417256.000 803040.000 711368.000
  UNITS meters
END
David V. Hildebrand
(403) 782-8239
www.afsc.ca <http://www.afsc.ca <http://www.afsc.ca/> >
  _____
Sent: Monday, December 06, 2010 4:37 PM
To: David Hildebrand; Brent Fraser
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] street maps
Sigh,
Get the link right!!
PDF summarising Bing/Google licelice issues
http://victorianspatialcouncil.org/cms/library/attachments/VSC%20Guidance%20Note%201_T&C%20Use%20of%20%20Google%20Maps%20and%20Bing%20Maps%20v1.0-May%202010.pdf
Brent Wood
To: "David Hildebrand" <David.Hildebrand at afsc.ca>
Date: Tuesday, December 7, 2010, 10:02 AM
David,
  This thread may get you started with OpenStreetMap.  Be sure to read Google's and Bing's Term Of Service.
http://lists.osgeo.org/pipermail/mapserver-users/2010-July/066061.html
Best Regards,
Brent Fraser
On 12/6/2010 12:18 PM, David Hildebrand wrote:
I want to add a street map (OpenStreetMap, Google, Bing, etc.) as a WMS layer but I'm not sure which service to use and what the URL would be to try them out?  My AOI is only about 10 by 10 degrees wide.
Any suggestions?
David V. Hildebrand
(403) 782-8239
mapserver-users mailing list
  mapserver-users at lists.osgeo.org <http://mc/compose?to=mapserver-users@lists.osgeo.org>
  http://lists.osgeo.org/mailman/listinfo/mapserver-users
-----Inline Attachment Follows-----
Michael Schulz
mschulz at webgis.de
in medias res
Gesellschaft für Informationstechnologie mbH
Schwimmbadstraße 2
D-79100  Freiburg i. Br.
Tel:  +49 (0)761 705798-102
Tel:  +49 (0)761 705798-0
Fax: +49 (0)761 705798-09
http://www.webgis.de / http://www.zopecms.de
Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20101209/cb5cb0e5/attachment-0001.html
