[mapserver-users] symbolizing polygon outlines
Brent Fraser bfraser at geoanalytic.com
Wed Dec 15 18:13:00 EST 2010
David,
   One technique is to render the polygon data twice; once as TYPE
POLYGON to render the fill, and again as TYPE LINE to render the polygon
outline as a dashed line.  You can use the same polygon data file for
each.  If you name the layers the same, they'll turn on/off together.
Best Regards,
Brent Fraser
On 12/15/2010 3:28 PM, David Hildebrand wrote:
> Is there a way of symbolizing a polygon outline other than with
> OUTLINECOLOR?  I would like to create a complex dashed line but it seems
> that polygons do not support that.
> Any suggestions?
> David V. Hildebrand
> Agriculture Financial Services Corporation
> (403) 782-8239
> www.afsc.ca<http://www.afsc.ca>
> This communication is intended for the use of the recipient to which it
> is addressed, and may contain confidential, personal and/or privileged
> information. Please contact Agriculture Financial Services Corporation
> immediately if you are not the intended recipient of this communication,
> and do not copy, distribute, or take action relying on it. Any
> communication received in error, or subsequent reply, should be deleted
> or destroyed. Please consider the environment before printing this
> email.
> mapserver-users at lists.osgeo.org
