[mapserver-users] Accessing NearMap tile server through MapServer
Michael Shishcu micklesh at gmail.com
Thu Dec 16 03:54:49 EST 2010
Hi Neil
Actually EPSG 4326 has extent +/- 90, +/- 180. Think you do not have blank
map, but everything in a single pixel in the center ;-)
try EPSG:900913 instead
hope this helps, regards, michael
On 16 December 2010 07:49, Neil Mercer
<Neil.Mercer at douglaspartners.com.au>wrote:
>  Hi,
> I’m attempting to access the NearMap service through MapServer.  Based on
> the documentation on the NearMap web site I have successfully created an XML
> file for GDAL to source imagery.  Testing via gdal_translate shows I can
> pull imagery OK.
> I’ve added the GDAL source to my mapfile as shown below, and have been able
> to have the layer show in a GetCapabilities request.  However if I attempt
> to request a map I get a blank image back from MapServer – no error, just a
> blank image.  Is there something obvious wrong?  Is there a way to verify
> the request being passed from MapServer to GDAL?
> Here’s my layer definition:
> LAYER
>                 NAME "NearMap"
>                 METADATA
>                                 "wms_title" "NearMap"
> END
>                 TYPE RASTER
>                 DATA "data/nearmap.xml"
>                 STATUS ON
>                 PROJECTION
>                                 "init=epsg:4326"
>                 END
>                 EXTENT -20037508.34 -20037508.34 20037508.34 20037508.34
>                 UNITS meters
> END
> Thanks,
> Neil.
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20101216/faad808b/attachment-0001.html
