[mapserver-users] OGR data layer type - points and lines
Stephen Woodbridge
woodbri at swoodbridge.com
Thu Dec 16 11:43:47 EST 2010
On 12/16/2010 10:51 AM, Ian Walberg wrote:
> Ah, ok let us look at that.
> I do believe the data source we have has data in the format POINT
> (-118.550003051999994 34.016666412399999).
> What is the format for line data?
I'm not sure, I have not used the OGR connection. Assuming it is
returning WKT where points are:
POINT(-118.550003051999994 34.016666412399999)
then lines would be:
LINESTRING(-118.550003051999994 34.016666412399999,-118.560003051999994
34.016666412399999,...)
-Steve
> Thanks
> Ian
> -----Original Message-----
> From: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Stephen
> Woodbridge
> Sent: Thursday, December 16, 2010 6:57 AM
> To: mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] OGR data layer type - points and lines
> I do not believe that this is possible.
> If you want to draw lines you have to create a data source the returns
> lines not points.
> The problem is that mapserver draws features and each point is a
> feature. It does not have a mechanism that can read a data source and
> aggregate the point features into a single line feature.
> I have seen posts on the PostGIS list for SQL that can do this. You
> might ask on the GDAL list if there is a way to do this. Or if you can
> use PostGIS, then you can find the SQL in the archives or ask again.
> -Steve W
> On 12/16/2010 1:00 AM, Ian Walberg wrote:
>> Hello list,
>> Using an OGR connection to an sqlite data file we can get point and
>> labels to draw successfully.
>> However when we try and draw a line using the point data we do not get
>> anything drawn.
>> Layer details below.
>> Thanks
>> Ian
>> LAYER
>> NAME ogr_points
>> STATUS DEFAULT
>> TYPE point
>> CONNECTIONTYPE OGR
>> CONNECTION "points.sqlite"
>> DATA "DataPoints"
>> CLASS
>> NAME "From OGR"
>> COLOR 255 0 0
>> STYLE
>> SYMBOL 'City'
>> SIZE 5
>> COLOR 0 255 255
>> END
>> LABEL
>> COLOR 255 255 255
>> OUTLINECOLOR 0 0 0
>> TYPE truetype
>> FONT Unicode
>> SIZE 16
>> ANTIALIAS TRUE
>> POSITION AUTO
>> END # end of label
>> END
>> END
>> LAYER
>> NAME ogr_line
>> STATUS OFF
>> TYPE line
>> CONNECTIONTYPE OGR
>> DATA "DataPoints"
>> CLASS
>> STYLE
>> COLOR 255 22 22
>> WIDTH 2
>> END
>> END
>> END
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
