[mapserver-users] draw hatch pattern with image file (ex. gif, etc)
Isao NASUNO isao.nasuno at ctc-g.co.jp
Thu Dec 16 23:24:06 EST 2010
Hi, Thomas,
Thank you for your response.
But, my question was wrong, I am sorry. What I want to do is filling up
polygon with a pattern using image file with transparency attribute.
Finally I found how to do it as following.
type polygon
class
   name "xxxxx"
   expression "x"
   color 255 200 200
   style
     symbol "pattern"  #
   end
end
SYMBOL
     NAME "pattern"
     TYPE pixmap
     image /home/myhome/pattern.gif
     transparent 1  # color index
END
It's closed, thank you,
Isao NASUNO
(2010/12/16 18:59), thomas bonfort wrote:
> if your image contains a hatch, yes, it's possible, although you can't
> change the color.
> if you want to create a hatch, use:
> symbol
>   name "hatch"
>   type hatch
> end
> layer
>   style
>     symbol "hatch"
>     color 0 0 0
>     angle 45 #hatch orientation
>     width 1  #line width
>     size 10  #spacing between lines
>   end
> end
> thomas
> On Thu, Dec 16, 2010 at 10:46, Isao NASUNO<isao.nasuno at ctc-g.co.jp>  wrote:
>> Hello all,
>> Is it possible to draw hatch pattern without symbol (vector)
>> but using small image file which have tranparency like gif etc ?
>> Layer type is polygon.
>> type polygon
>> class
>>   name "xxxxx"
>>   expression "x"
>>   color 255 200 200
>>   style
>>     image smallimage.gif   #<-- like this..
>>   end
>> end
>> Thanks,
>> Isao NASUNO
