[mapserver-users] GetFeatureInfo
David Hildebrand David.Hildebrand at afsc.ca
Fri Dec 17 11:01:59 EST 2010
The tolerance parameter was the trick, Jeff.  Thanks.
David V. Hildebrand
Agriculture Financial Services Corporation
(403) 782-8239
www.afsc.ca <http://www.afsc.ca>
This communication is intended for the use of the recipient to which it
is addressed, and may contain confidential, personal and/or privileged
information. Please contact Agriculture Financial Services Corporation
immediately if you are not the intended recipient of this communication,
and do not copy, distribute, or take action relying on it. Any
communication received in error, or subsequent reply, should be deleted
or destroyed. Please consider the environment before printing this
email.
-----Original Message-----
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Jeff
McKenna
Sent: Thursday, December 16, 2010 1:57 PM
To: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] GetFeatureInfo
On 10-12-16 4:41 PM, David Hildebrand wrote:
> I have several WMS layers. One is a polygon layer and the other two
are
> line and point layer. I have HTML templates for each layer which are
> very similar. All the layers are being drawn but when I run a
> REQUEST=GetFeatureInfo on a location which has features from all three
> layers I only get a return from the polygon layer. I have the
following
> debug statements in my mapfile.
Just a quick note, that the WMS Server doc gives a working example of a
GetFeatureInfo request on a point layer:
http://demo.mapserver.org/cgi-bin/wms?SERVICE=WMS&VERSION=1.1.1&REQUEST=
GetFeatureInfo&BBOX=-11.332970,24.121208,47.584718,57.965035&SRS=EPSG:43
26&WIDTH=1001&HEIGHT=575&LAYERS=cities&STYLES=&FORMAT=image/png&TRANSPAR
ENT=true&QUERY_LAYERS=cities&INFO_FORMAT=text/plain&X=229&Y=280
I would make sure your layers have a template set, as well as modify the
tolerance parameter possibly.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
