[mapserver-users] crash on SYMBOL
Alan Boudreault
aboudreault at mapgears.com
Tue Dec 21 15:24:42 EST 2010
Fixed and committed in r10809.
Alan
On December 21, 2010 02:25:44 pm Daniel Morissette wrote:
> Bart,
> Is "604310017" a symbol name? If you add quotes around it in the mapfile
> then the entry should be treated as a symbol name and the seg fault
> would go away, can you verify that?
> I suspect the integer value 604310017 (without quotes) is treated as an
> index and used to access the array of symbols without bounds checking.
> Please file a ticket and we'll have a look.
> Daniel
> Bart van den Eijnden (OSGIS) wrote:
> > Hi list,
> > we have some faulty MAP files, which did not crash MS 5.2, however they
> > do seem to crash MS trunk.
> > It results in a segfault (e.g. in a WMS GetCapabilities request) when we
> > use e.g.
> > SYMBOL 604310017
> > Any idea what has changed in the meantime to cause this to segfault?
> > TIA.
> > Best regards,
> > Bart
> > mapserver-users mailing list
> > mapserver-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
Alan Boudreault
Mapgears
http://www.mapgears.com
