[mapserver-users] Projection and mapquery
Morten Sickel
Morten.Sickel at nrpa.no
Tue Feb 2 04:51:39 EST 2010
Josh, Thanks, but could you please elaborate this a bit? Do you mean that you are doing a reprojection in mapscript of the projected layer or that you are projecting the layer 'as saved' before mapserver gets to see i at all?
since the query is towards the map object, I cannot see how I can do any more reprojection of the layer, except what has been done when the layer was plotted.
Morten Sickel
Norwegian Radiation Protection Authority
-----Original Message-----
Sent: Thursday, January 28, 2010 8:42 PM
To: Morten Sickel
Subject: Re: [mapserver-users] Projection and mapquery
I have to wrap my head around this subject every time I come back to it.
I've only done this using $layer->queryByPoint() and I tend to project both the layer and the point into the map projection.
Not much of a hint but something to consider, Josh
Morten Sickel wrote:
> I presently have a set up in which I plot some measurements on some
> background maps. Things work fine, but I want to add the possibility
> to query the measurement data set by clicking on a measurement. The
> measurements have coordinates in lat lon and I only manage to query
> those data if I plot the entire map in the same projection.
> Are there any ways to overcome this? As I am mostly working on maps from 60 deg north and upwards, geographical projection
> is not the projection of choise and I would prefer not having to reproject the measurement data.
