[mapserver-users] areas of high res
TC Haddad
tchaddad at gmail.com
Tue Feb 2 18:10:40 EST 2010
use two different tile indexes and use MIN- and MAXSCALEDENOM to control
when they are each used.
presumably you already have one tileindex working for the nationwide 500,000
scale images?
so make a second one that is a compound index - looks like the above, but
also includes the footprints of the 250,000 areas (replacing the 500,000
references in those areas). Switch between the two something like this:
LAYER
NAME "Overview Imagery"
STATUS OFF
TYPE RASTER
TILEINDEX "img_index_500k"
TILEITEM "PATH"
MINSCALEDENOM 300001
END
LAYER
NAME "Detailed Imagery"
STATUS OFF
TYPE RASTER
TILEINDEX "img_index_250k"
TILEITEM "PATH"
MAXSCALEDENOM 300000
END
On Tue, Feb 2, 2010 at 1:34 PM, Wendell Turner <wendell at enflight.com> wrote:
The base layer of my map has full coverage of the US at a
> scale of 1:500,000. That works fine. I have some areas of
> detail that have tif files at a scale of 1:250,000. What do
> I put in the mapfile to say 'use high res if available for
> this tile, otherwise use the low res one'?
> Thanks,
> Wendell
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100202/38225134/attachment.html
