[mapserver-users] high quality print from external wms
Bart van den Eijnden bartvde at osgis.nl
Wed Feb 3 09:55:19 EST 2010
Marco,
this is not exactly right.
Only WMS 1.3 has elements in the GetCapabilities response to advertize this limit (MaxWidth and MaxHeight). WMS 1.1.X did not have this mechanism.
You are using MS 5.1, and there is no WMS 1.3 support in that version. So it's logical that Mapserver can't advertize those limits in WMS 1.1.X.
Best regards,
Bart
On Feb 3, 2010, at 3:39 PM, DeDuikertjes wrote:
> Hi,
> WMS services do often have an upper limit for the output image size.
> According to WMS specs they should advertise that in response to a getcapabilities request.
> Despite that, Mapserver doesn't always do that. At least my version (5.1) doesn't.
> Piecing together an image from smaller pieces isn't that easy when labels are involved (and perhaps also when hatch symbols are involved).
> Cheers, MArco
> Rahkonen Jukka schreef:
>> Hi,
>> WMS servers have often an upper limit for the output image size.  If
>> that is the case you can not do anything else than capture the print
>> area in smaller pieces and combine them with your application.  Test the
>> service by sending WMS calls manually with different HEIGHT and WIDTH
>> parameters.
>> -Jukka Rahkonen-
>>  Puolesta Basti2025 wrote:
>>> Hi all,
>>> i got an external wms included in my mapfile, like this:
>>> LAYER
>>> NAME 'grenzen_50000'
>>> TYPE RASTER
>>> STATUS ON
>>> CONNECTION 'http://....????????????????..........?SERVICE=S&'
>>> CONNECTIONTYPE WMS
>>> METADATA
>>> 'wms_srs' 'EPSG:31467'
>>> 'wms_title' 'Grenzen 50000'
>>> 'wms_name' 'grenzen_50000'
>>> 'wms_format' 'image/png'
>>> 'wms_server_version' '1.1.1'
>>> 'wms_onlineresource'
>>> 'http://....????????????????..........SERVICE=S&version=1.1.
>>> 1&service=S&request=GetLegendGraphic&layer=grenzen_50000&for
>>> mat=age/png&STYLEÞfault'
>>> END
>>> END
>>> Normaly the wms is not able to print with 288dpi.
>>> My question is, how can i mod my mapfile so that i can use high quality
>>> print with an external wms.
>>> thx,
>>> basti --
>>> View this message in context: http://n2.nabble.com/high-quality-print-from-external-wms-tp45
>>> 00369p4500369.html
>>> Sent from the Mapserver - User mailing list archive at Nabble.com.
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
